Looking for used 50-70hp, pre-emissions tractor. JD?
   / Looking for used 50-70hp, pre-emissions tractor. JD? #31
I've had similar thoughts about different brands and their loader ratings. It's not like it is difficult or expensive to make a loader lift more weight. Any mechanic can do that quickly & for not much money. For a manufacturer to increase lift is no cost at all.
And Kubota has to know that their loaders are rated to lift less than others, just like they have to be aware that their lower loader lift spec is costing them sales.
But they do it anyway. What does that tell you?
rScotty
My opinion, is it tells me they don't believe it is costing them enough sales to matter. Or they simply believe in their design and specs for what they want to offer.
I also think the lost sales aren't because of a loader. It's because some people are strictly buying on price and will find a reason to buy the cheapest option regardless. Being the cheapest isn't Kubota's model.
I equate a lot of this to the car market. BMW & Mercedes do quite well, but Kia's are fine too for a segment of the market.
   / Looking for used 50-70hp, pre-emissions tractor. JD? #32
Loader lift specs are a lot like vehicle tow ratings, in that there are a lot of internal corporate engineering standards and criteria that have to be met in order to advertise a lift capacity value.
In the vehicle world, it’s not only if the vehicle will tow a given trailer up a given hill at a target speed. There are dozens of other parameters that have to meet targets, like oil temp, coolant temp, ecu temp, transmission temp, and manual transmission clutch durability qualification.
Miss any one of the criteria and the advertised capability has to be diminished by corporate policy.
If the loader causes the tractor to become unstable beyond a certain load, a competent and responsible tractor manufacturer would establish that load as the advertised maximum for that particular model.
There are probably dozens of tests and criteria to pass before marketing can establish a higher advertised lift value.
   / Looking for used 50-70hp, pre-emissions tractor. JD? #33
I have been looking for a larger tractor to replace or go with my Kubota L4400 4wd. The L4400 is 45 hp and is a good machine but it is very light weight. I need something heavier and with substantially more loader capacity. I'm looking for a used pre-emissions tractor with no computer. I'm looking in the 60-70 hp range. My ideal machine is a Kubota M6040 or M7040. Needs to be 4wd. But these are hard to find and as everyone knows these pre-emissions tractors are EXPENSIVE right now. I looked at a M7040 with 1800 hours on it. Beat up. Bent exhaust pipe. One of the front wheels and tires was new which makes me wonder what happened to it. Otherwise it was solid. Drove and functioned well. No obvious leaks etc. $28,500! And searching the web that's consistent with what else is out there. I've made a casual offer of $22,000 but haven't heard back. Can't imagine he'll get anywhere close. But it has been sitting there a while.
So, I need to broaden my horizons. That would primarily mean John Deere or other popular brand with good local dealer support. But I don't know anything about brands other than Kubota. I would prefer a mechanical shuttle shift. Would consider hydraulic shuttle shift. No hydro. What would the JD equivalent of a Kubota M6040 or M7040 be? Any thoughts or recommendations appreciated.
New tractors are generally in short supply and thus used ones have become pricey as well.
Deere's pre-emissions tractors in the 60-70 HP range would be certain 5000 series machines up until 2013, and before that, the smaller members of the 2x40/2x50/2x55 series as they introduced MFWD on the 40 series units in this HP range. I will say that MFWD was pretty uncommon until roughly the late 1990s, so it would be pretty uncommon to find a 40/50/55 series unit with it and it wasn't even that common on the first 5x00 units. The units you would want to look for are the 5300 and 5400, 5310, 5320, 5303, 5325, 5403, and 2008-2013 5065E and 5075E as well as 5065M and 5075M. Do note that the 5065E, 5075E, and 5075M are still made and you would need to narrow your search to 2013 and older units in order to not turn up 2014-up Tier 4 units if you want a pre-emissions tractor. These tractors depending on year and model series could have an unsynchronized 3-range/3-speed Collar Shift transmission, a 3-range/3-speed synchronized SyncShuttle (also called the TSS or "top shaft synchronized") transmission which does NOT have a shuttle lever, or one of a few different hydraulic reverser (PowrReverser) transmissions with the shuttle lever, most commonly a three-range/four-speed unit. Deere never made a mechanical shuttle transmission for these tractors with a shuttle lever like you would see on a New Holland Workmaster 60 or 70 aka the CaseIH Farmall 60A and 70A. They also never made a hydrostatic transmission for this size of tractor either.
The Deere 5000 series are a nice tractor, the same basic design has been made since the early 1990s and the basic 3 cylinder 179 CID/2.9 L engine in nearly all of those has been made since the 1970s. The exception here is the 5325 and Tier 2 5065M/5075M. They used a five-cylinder skid loader engine and the 5M used/uses a new, different, larger frame than the other tractors in this list. I have run several three and four-cylinder versions in the 5000 line over a couple of decades, both cabbed and open station, 2WD and MFWD, and with the TSS as well as 12-speed PowrReverser transmissions. They all worked well, I personally prefer the TSS transmission despite there being no reverser lever, but that is personal preference.
Deere's comparable models to the M6040 and M7040 would have been the 2008-2013 5055E and 5065E/5065M.
Regarding loader carriers, the "ALO" type above is called Global and is an ISO spec. CaseIH/New Holland as well as John Deere give it as an option on some loaders. The other carrier CaseIH/New Holland uses is the skid loader QA, which is an option if not the only setup offered on loaders on <75 HP tractors. Deere offers their own hook-and-linch pin JD 500 QA on all of their 500 series loaders, and on some loaders they offer Global and on some new ones, skid loader QA. Kubota appears to only use the skid loader QA on tractors of this size. I personally like the JD QA as it's the easiest and most foolproof of the three mentioned above, and it is not proprietary. Most 500 series Deere loaders made before about 2010 or so are going to be Deere QA.
I will also say to not rule out a 2WD utility tractor unless you have actually used a 2WD utility tractor on your property and had issues with it. A utility tractor has a lot more weight than a compact, and particularly with the fluid-filled ag (R1) tires that generally come on them, a 2WD utility tractor will get a lot more traction than compact tractor with MFWD disengaged will get. They work just fine with a loader, you just need to have appropriate ballast, which you are supposed to have on any tractor with a loader. With the exception of the smaller Kubota M series units with their bevel gear MFWD as you see in a compact tractor, the 2WD tractors have a much smaller turning radius than a regular planetary-hub MFWD utility tractor as well, which is why they are popular for haying operations around here.
   / Looking for used 50-70hp, pre-emissions tractor. JD? #34
Thanks for that real complete synopsis on the larger JD utility tractors & loaders. BTW, wasn't there a high quality loader made a few decades back by the ALO company? Maybe in Canada? I remember something of that.
You changed my mind on on thing, which is I have long been in favor of the SSQA just because it opens up a whole world of rental options. But I am realizing I haven't taken advantage of those rentals myself, and I have several times now mis-mated my SSQA with the few front attachments I have... and then worrried about someday tweaking the SSQA. All that adds up to my beginning to look around just to see if there really are better QAs out there. I'm probably not going to change, but I would like to know.
I hear you on the 2WD. I suspect that a 2wd is going to be the cost-wise sweet spot right now in used pre-emission tractors. Once you get over 70 hp, the 2WD machines have a lot of traction, they are real reliable, and they steer nicely. They just aren't popular against the same machine in 4wd and that might be the one way to save serious money. Now if you have hills, snow, and ice, then best stay with 4wd. But consider it. When I buy used, I worry about the 4wd. It's the one mechanical system difficult to evaluate.
rScotty
2wd is simply not an option. Too many hills. Too much slick mud. With Kubota 4wds I don't think there is a big compromise in turning radius due to the bevel gear design. I could be wrong.
My inlaw next door to my place is a cattle rancher and grows his own hay. For years he had only large 2wd tractors. Most of them from the 70s. Case and JD. He has his own shop and keeps them running. But about ten or 15 years ago he was going downhill pulling two loaded hay wagons. It was muddy and the tractor started to slide and the wagons jackknifed and piled into the tractor and almost rolled it. Scared the crap out of him. He still uses his 2wd machines for mowing, raking and baling which is primarily in his flat hay fields. But he has newer and larger JD 4wd for everything else.
@mo1 Thanks for that rundown. It is very helpful.
Another thought on 2wd. Most of the Kubotas that I see that are 2wd do not have loaders. Many of them have big turf tires on them.
   / Looking for used 50-70hp, pre-emissions tractor. JD? #37
rScotty
It is not too hard to get the skid loader QA at a little bit of an angle and get one of the latches in front of its slot, or have one of the slots get caked with mud or dirt and keep the latch from latching properly. I have never rented a loader attachment but most of the ones I have seen at the local rental yards are very much skid loader attachments such as hydraulic rock hammers, rotary brooms, and brush cutters and they require the much higher hydraulic flow of a skid loader. Unless the rental yards around you are different, if you wanted to be able to use one of those kinds of attachments, you would have to buy one of them anyway in order to get a low-flow version that would work with a utility tractor.
As far as Deere tractors are concerned, the real big difference in tractor size in going up from the 45-75 HP 3 cylinder 5000 series isn't going up to the slightly larger 4 cylinder models like the 5500, 5410/5420/5425, 5510/5520/5525, and 5083E/5093E/5101E etc., it is when you go from the 5000 series to the 6000 series as there is a very noticeable increase in size and weight. The 5000 series units topped out at about 90-125 HP depending on year, and the 6000 series units started at about 85-105 HP depending on year. There are a lot of 6000 series machines out there, particularly around here as a ~120 HP 6000 series tractor is pretty popular size to make and feed round bales and most all of the farming around here is cattle and hay.
   / Looking for used 50-70hp, pre-emissions tractor. JD? #38
Regarding 2wd and using the front end loader...I've found that if I lift a bucket of heavy material with my 2wd John Deere and the tractor is not on firm hard ground, I can't back up. Both rear tires just spin because of all the weight in the bucket out in front of the tractor. Same with my Kubota when it is in 2wd...but at least with it I engage 4wd and then it backs up out of the pile no problem.
   / Looking for used 50-70hp, pre-emissions tractor. JD? #39
Kubota doesn't use DEF on either the M7060 or M4 which are both over 70HP. Not sure about Deere.
Thank you. I get a little confused on all the smog systems out there. Kubota M4 and 7060 uses DPF, EGR and Regen.
   / Looking for used 50-70hp, pre-emissions tractor. JD? #40
Correct, the bevel gear design does not reduce the turning radius the same way a planetary setup does. I do suspect it is not as strong as a planetary setup as virtually all other utility-sized and larger tractors have a planetary setup, while bevel-gear setups are seen in compacts, and unfortunately I have seen a couple of bevel gear MFWD setups which were broken.
Engines from about 26 through 74 HP have to abide by strict particulate, nitrogen oxide, hydrocarbon, and sulfur dioxide emissions regulations. It's not as strict as 75-600 HP regs, which essentially require an additional catalyst (SCR) with urea (DEF) involved in the chemical reactions, so this is why there is no DEF on under-75 HP units. I have seen no engine in this size range which does not have a diesel oxidation catalyst (DOC), if it has a DPF, it is actually a combination DPF/DOC unit- that table is incorrect, Deere and Kubota both do have a combination DPF/DOC unit. Manufacturers can either keep their exhaust gas temperatures high all of the time to use the DOC face to burn off soot, or they can use a particulate filter (DPF) to catch the soot, generally run the engine at normal exhaust gas temperatures but then periodically run at high EGTs to burn off the trapped soot in the filter. Most manufacturers use a common-rail electronically-controlled direct injection engine for 26-74 HP Tier 4 unit, although at least one smalelr one does not, or did not. Some use EGR, some do not. CNH and Kubota use EGR in this size of engine, Deere does not.
2014 Chevrolet Cruze Sedan (A51694)
2014 Chevrolet...
2010 Nissan Sentra Sedan (A51694)
2010 Nissan Sentra...
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
New/Unused 7ft 8 Drawers and 8 Cabinets Workbench (A51573)
New/Unused 7ft 8...
John Deere 9620R Tractor (A53342)
John Deere 9620R...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A53472)
UNVERFERTH 330 -...
