Looking for two piece rear rims
   / Looking for two piece rear rims #1
goatman
southern ohio
NH TC 30
I bought a TC 30 and it came with one piece rear rims. /forums/images/graemlins/mad.gif. I have loaded the tires and turned the rims around and have 60" across the rear.I still have an uneasy feeling when not on even ground. /forums/images/graemlins/frown.gif Does any one know where I can order 2 piece rims?? Would this widen much more and be worth the expence?? Thanks for any and all suggestions... I have tried to find some web sites but if I search tractoc xx get a bunch of truck info... /forums/images/graemlins/confused.gif
Doesn't anyone have information???? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
   / Looking for two piece rear rims #3
I guess not . Sorry I have no information on 2 piexe rims either. How about dual rear tires ? Is that doable ? It does increase stability a LOT.
YES!!!! What have you got??? /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
I have talked with John at heywheel and he says he can get me two peice rims at reasonable cost but I was wondering how much it would add in width.. Thanks for the other source "Miller". /forums/images/graemlins/grin.gif
   / Looking for two piece rear rims #7
I guess you will need the dimensions on the rims, ie how much offset from center will they give you vs your current rims.
Dual rears add a lot of stability, more than just wider rear tires.
I have used tractors with dual rears and they tend to slide sideways instead of turn over. Lots more ballast for loader work too.
Not sure if they are recommended for your tractor or not.
   / Looking for two piece rear rims #8
Have you looked at the online catalog from OTR engineering?
They make all kinds of wheels and I "believe" they are the OEM supplier for most tractor companies.
Take a look at OTR Wheel Engineering
Leroy
Leroi, Thanks a bunch!!! I'll call them tomorrow.. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
2012 Ford F550 Dump (A55272)
2012 Ford F550...
2009 CATERPILLAR 308D CR EXCAVATOR (A52709)
2009 CATERPILLAR...
MASSEY FERGUSON REAR TIRES (A58374)
MASSEY FERGUSON...
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
(2) LOAD RATCHETS FOR DTAKE POCKET (A52708)
(2) LOAD RATCHETS...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
