Looking for two piece rear rims
   / Looking for two piece rear rims #1
goatman
southern ohio
NH TC 30
I bought a TC 30 and it came with one piece rear rims. /forums/images/graemlins/mad.gif. I have loaded the tires and turned the rims around and have 60" across the rear.I still have an uneasy feeling when not on even ground. /forums/images/graemlins/frown.gif Does any one know where I can order 2 piece rims?? Would this widen much more and be worth the expence?? Thanks for any and all suggestions... I have tried to find some web sites but if I search tractoc xx get a bunch of truck info... /forums/images/graemlins/confused.gif
Doesn't anyone have information???? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
   / Looking for two piece rear rims #3
I guess not . Sorry I have no information on 2 piexe rims either. How about dual rear tires ? Is that doable ? It does increase stability a LOT.
YES!!!! What have you got??? /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
I have talked with John at heywheel and he says he can get me two peice rims at reasonable cost but I was wondering how much it would add in width.. Thanks for the other source "Miller". /forums/images/graemlins/grin.gif
   / Looking for two piece rear rims #7
I guess you will need the dimensions on the rims, ie how much offset from center will they give you vs your current rims.
Dual rears add a lot of stability, more than just wider rear tires.
I have used tractors with dual rears and they tend to slide sideways instead of turn over. Lots more ballast for loader work too.
Not sure if they are recommended for your tractor or not.
   / Looking for two piece rear rims #8
Have you looked at the online catalog from OTR engineering?
They make all kinds of wheels and I "believe" they are the OEM supplier for most tractor companies.
Take a look at OTR Wheel Engineering
Leroy
Leroi, Thanks a bunch!!! I'll call them tomorrow.. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
UNUSED FUTURE BK56 56" HYD BACKHOE DIGGING ARM (A58376)
UNUSED FUTURE BK56...
(INOP) 2006 FREIGHTLINER M2 DAYCAB ROAD TRACTOR (A58375)
(INOP) 2006...
2010 SHOP MADE MARATHON 25KW GENERATOR (A58216)
2010 SHOP MADE...
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
SKID STEER MOUNTING PLATE (A58376)
SKID STEER...
UNUSED RAYTREE RMVB78-78" VIBRATING BUCKET (A58376)
UNUSED RAYTREE...
