looking for the right size and brand of compact tractor
   / looking for the right size and brand of compact tractor #21
The red, blue, green, and orange tractors are nice but in my opinion you are paying extra for the paint. There are many good tractors out there that have more standards, which are costly options on the well known brands, for less money and longer warranty.
Just take your time and go drive the different models. You may find you like the way one tractor feels over others. While driving a model you think meets your needs, make sure if you want a front end loader, the one you drive also has that option installed. You may find you have a better view of the bucket on one brand over another for instance. Don't rule out the lesser known brands, you may be able to purchase a bigger machine for the same money as a smaller well known brand.
All tractors will break down at some point so don't forget about dealer service.
And finally no one has mentioned TYM tractors in case there is a dealer in your area for them. They have a good balance of quality, affordability, and standard options.
   / looking for the right size and brand of compact tractor #22
yes the loader capacity would be the deciding factor.. Im use to a skid loader with about 2000#s of lift.. I know thats asking to much for a smaller tractor. so Im not a 100 % sure whats common.
I have a tractor with a 2000+ LB. lift and ever since I got the little guy I just don't use the big guy that much. I have just under a 1000 LB. lift on the smaller tractor and find it sufficient for most chores. Maneuverability is excellent, what you lose in grunt you make up for in nimbleness. You can always cut the logs a bit shorter and tailor your work to the tractor. Guess it depends on what the majority of your work will be......
   / looking for the right size and brand of compact tractor #23
Buy the nabor with the 200 acres his favorit brand of beer a case per month and use his tractor and all will be happy.
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
2019 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2018 CATERPILLAR 336FL EXCAVATOR (A52141)
2018 CATERPILLAR...
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
