Looking for Salvage Yards in Europe
   / Looking for Salvage Yards in Europe #1
mike48130
Platinum Member
Plymouth, MI
JD 4410, 4210 Ford 1700, 550, Bobcat 843
I have a Ford 550 TLB with the European side shift backhoe. I am looking for a hydraulic valve for the slide clamps. Mine was never used and got water in it and seized. I got it freed up, but not in good shape. I tried the Googler, and can't seem to find many yards over there. These side shifts seemed to be pretty popular over there, so I was hoping to find a good usable valve.
Part number: 81903475
Thanks for any help.
   / Looking for Salvage Yards in Europe #2
I might have one off a Case if that would work.
   / Looking for Salvage Yards in Europe #3
I've found this by just running the part number.
https://avspare.com/spare/new.holland/81903475/ Or Messicks also has this part number on their catalogs.
There is a tractor/machinery salvage yard here in Portugal that does stock parts for pretty much any tractor or industrial machine available in Europe.
Here a link for the English website: AGRIPRONTO.COM
Try sending them an email with the parts you need and hopefully they can help you. A word of caution, they are known to be quite pricey on their parts.
On another note, I believe it's just uses a simple 3 way valve that any hydraulic shop should be able to help you.
Thanks.
The AVSPARE web site has 2 request for the parts, but no parts. I am one of the requesters about 8 months ago.
I'm not sure it is a simple valve. It has a second shuttle type spool in it, not sure what that is doing. IT only operates a single acting spring loaded cyl, so it should be, but they have something else going on. I looked at the 555 TLB's, and they have a different version that doesn't mount the same. That is my backup plan to try to find a used on of those. It has the same second shuttle in it as well.
Here is the valve, item #1.
Any pictures or part number, or what it came off so I can try to cross reference?
(INOPERABLE) MAROOKA (A50854)
(INOPERABLE)...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A49461)
2016 Ford F-150...
2014 UTILITY 53FT DRY VAN TRAILER (A51222)
2014 UTILITY 53FT...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2016 Ford F-150 Crew Cab Pickup Truck (A49461)
2016 Ford F-150...
