Looking for Salvage Yards in Europe
   / Looking for Salvage Yards in Europe #1
mike48130
Plymouth, MI
JD 4410, 4210 Ford 1700, 550, Bobcat 843
I have a Ford 550 TLB with the European side shift backhoe. I am looking for a hydraulic valve for the slide clamps. Mine was never used and got water in it and seized. I got it freed up, but not in good shape. I tried the Googler, and can't seem to find many yards over there. These side shifts seemed to be pretty popular over there, so I was hoping to find a good usable valve.
Part number: 81903475
Thanks for any help.
   / Looking for Salvage Yards in Europe #2
I might have one off a Case if that would work.
   / Looking for Salvage Yards in Europe #3
I've found this by just running the part number.
https://avspare.com/spare/new.holland/81903475/ Or Messicks also has this part number on their catalogs.
There is a tractor/machinery salvage yard here in Portugal that does stock parts for pretty much any tractor or industrial machine available in Europe.
Here a link for the English website: AGRIPRONTO.COM
Try sending them an email with the parts you need and hopefully they can help you. A word of caution, they are known to be quite pricey on their parts.
On another note, I believe it's just uses a simple 3 way valve that any hydraulic shop should be able to help you.
Thanks.
The AVSPARE web site has 2 request for the parts, but no parts. I am one of the requesters about 8 months ago.
I'm not sure it is a simple valve. It has a second shuttle type spool in it, not sure what that is doing. IT only operates a single acting spring loaded cyl, so it should be, but they have something else going on. I looked at the 555 TLB's, and they have a different version that doesn't mount the same. That is my backup plan to try to find a used on of those. It has the same second shuttle in it as well.
Here is the valve, item #1.
Any pictures or part number, or what it came off so I can try to cross reference?
2015 MACK GU713 WINCH TRUCK (INOPERABLE) (A50854)
2015 MACK GU713...
71052 (A49346)
71052 (A49346)
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A51039)
2019 Energreen EVO...
197637 (A50459)
197637 (A50459)
GARDNER DENVER 480 VOLT AIR COMPRESSOR (A50854)
GARDNER DENVER 480...
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A51243)
2007 INTERNATIONAL...
