Thumb Looking for Mechanical Thumb for Older Kioti Backhoe
   / Looking for Mechanical Thumb for Older Kioti Backhoe #1
BubbaSam
North Central MA
Kioti CK30 HST
Hello to all...
I have a 2005 Kioti CK30HST with a KB2375 Backhoe. I am looking for info on adding a Mechanical Thumb. Clamp-on is fine. It's not going to get a LOT of use but like it's been said on the forum... "You're only using half of the abilities of your BH if you don't have a thumb."
Does ANYONE have any suggestions for such an item as for Where, Brand, Good/Bad comments, etc.?
Thanks for all your help guys...
   / Looking for Mechanical Thumb for Older Kioti Backhoe #2
I got mine from Michigan Iron & Equipment.
I didn't like getting on/off the tractor to adjust the manual thumb, when I upgraded my CK30 to a DK40, I got a hydraulic thumb. I would never go back to a manual thumb, but a manual thumb is MUCH better than no thumb. Good luck.
Hello to all...
IXLR8
First... THANK YOU for your reply and the reference to Michigan Iron.
I totally agree with you that the hydraulic WOULD be better but I would have to do some additional plumbing as well. BUT... you hit the nail on the head that a mechanical is better than nothing... and that's what I have now... NOTHING!
   / Looking for Mechanical Thumb for Older Kioti Backhoe #4
IXLR8
If you have hydraulics for the backhoe you have everything you need for a hydraulic thumb. If you order a hydraulic thumb from MIE, then you will have everything you need. The thumb controls come with the hoses and fittings to tie into the hydraulics of the BH.
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2015 FREIGHTLINER...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
2020 MDB UT125KPLUS FLAIL MOWER (A51247)
2020 MDB...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2014 MACK GU713 WATER TRUCK (A54756)
2014 MACK GU713...
