Looking for loader valve...
/ Looking for loader valve...
Well the valve and joystick are installed. I am now waiting on a 320R loader to show up. I would love to have a grapple. I noticed that the spool valve they installed has 3. 2 valves are used for the loader. Can the third be used for a grapple? Is there a kit JD makes or anyone that could be installed to add that third function to control a grapple? valve top.jpg
/ Looking for loader valve... #23
Yes I would think that diverter kit would work. It would just divert the flow from your curl function on the loader and allow the grapple to move when you move the handle.
Great Job on the install! That looks great!
Is there a kit that I could use that would keep my curl function and also allow me to use the clamp?
/ Looking for loader valve... #25
Yes. You can use the third spool on the valve you have if you want. Just have to figure out a handle as I believe those kits are no longer available.
You can also buy a true 3 function kit from several places on line or source a valve and buy the hoses and fittings separately. These would use the power beyond from your loader valve if it has the Power Beyond plug. Not positive on that though.
Even with a true 3rd function you most likely still will only be able to work one function at a time. A diverter like you posted works fine for most people. It only diverts the flow while you have the switch engaged. Release the switch and you can curl.
Ok thanks!! I may just go with that kit. They had said (JD) that the loader would take 6 weeks to get. Is that normal?
/ Looking for loader valve... #27
Doesn't sound unreasonable. But I have no idea on what wait times should be for a loader. My hope is they treat you right on the deal.
/ Looking for loader valve... #28
I used the existing 3rd spool valve on one of my 4300s, but not with the factory lever that goes into one of the slots on the fender.
Instead, I bought a few of the parts from JD, then a standard remote cable, then made a lever that mounted on my ROPS mast. It was
for a hyd toplink, but could be used for an FEL accessory like grapple or 4n1.
If you want to see how I did it, start at post #250 here:
https://www.tractorbynet.com/forums/parts-repairs/146974-john-deere-4300-complete-rebuild-7.html
OK guys I found this kit and they say it is available. Would this work? LVB25084
/ Looking for loader valve... #30
I sure would think so. It will route to the back of the tractor requiring longer hose to run to the grapple but would work. My brother used his rear remotes for his grapple. He doesn't seem to mind.
Just wanted to give you guys an update. I now have the loader installed. I also purchased another valve kit that is for the rear of the tractor and I have hoses running to the front for a grapple. I have yet to even use the bucket as I have been busy for a couple days using the grapple. The tractor as I had said is a 4410 but they were able to put a 320R loader on it. It is working out great. I am trying to get some pictures uploaded for you but for some reason my phone has decided it does not want to send them to my computer....
/ Looking for loader valve... #32
Congratulations on getting it done! Thanks for the follow up and yes pictures please!
/ Looking for loader valve... #33
Email them to yourself. There are lots of free email services out there if you do not have more than 1 account.
Personally, I recommend everyone has at least 2 (the second one for all the places that require an email be included but send out huge amounts of crap) I have one that I check about 2-3 times a week and generally delete everything in it, often by the 100’s.
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
STERTIL SKY LIFT (A67714)
STERTIL SKY LIFT...
2018 Deere 650K LGP (A64127)
2018 Deere 650K...
Front Tank Bracket (A64126)
Front Tank Bracket...
x (A68191)
x (A68191)
