landini mythos loader hydraulic plumbing
   / landini mythos loader hydraulic plumbing #1
mac111
cal
mf135
hi all ..just brought a landini mythos 110hp tractor and now have purchased a trima front end loader complete with the loader brackets for a mythos ,so fitting wont be an issue..
i am having trouble finding out where the 3 hydraulic hoses plumb into the back of the tractor ,,the manual that came with the tractor doesnt help .
the mythos has trailer brakes port fitted ..
some help or photos would be appreciated..
thank you in advance
regards
mac
   / landini mythos loader hydraulic plumbing #2
What - no owners manual for the front end loader. My Kubota tractor owners manual is no help for the FEL either. I did get an owners manual for the FEL.
   / landini mythos loader hydraulic plumbing #3
Since you state 3 hoses I suspect the trima loader has a control valve included for controlling the raise - lower and curl- dump functions. If this is true you will have to figure where to access pressure, connect power beyond to run rear remotes and 3 point and a place to connect tank directly back to tank.
Before doing anything I would suggest obtaining a manual for the loader and tractor so that you can verify all the connections without concern for damage to a component if connected incorrectly
hi oldnslo
thank you for your reply ...the trima loader manual was of no help in that area ,,nor was the mythos manual
but after a lot of research we figured out where the dump return fed back into the back of the tractor ..
unusual place as all our other machines the return is quite obvious
its a great tractor ,,heaps of grunt and strong hydraulics
regards
mac
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A45679)
2005 INTERNATIONAL...
John Deere Corn Head (A49251)
John Deere Corn...
John Deere 960 21ft. Field Cultivator (A49339)
John Deere 960...
Lonestar Panels (A49339)
Lonestar Panels...
45026 (A48082)
45026 (A48082)
2006 Isuzu NPR Flatbed Landscape Truck (A46683)
2006 Isuzu NPR...
