Looking for Help!
   / Looking for Help! #1
headfirecracker
grundy va
Power Trac 2430
Hello to all I would like to start saying im new to tractorbynet. In a bit of a bind. A huge rock slid off and hit my tractor, breaking the shaft off my wheel motor, also the front casing. I called terry and described the issue, he told me at first 350 to reseal with new shaft and bearing. Untill I sent him pictures, now with the front casing busted (which I thought was, and hoping a bearing) was a different motor all together, is now 1130 bucks. I would like to find a similar motor to replace it with, or all 4 so if something happens like this again I wouldn't be out this crazy marked up price. The shaft is 1"X20tpi.
Thanks in advance
Firecracker
   / Looking for Help! #2
First, Welcome to TBN! :thumbsup:
Second, OUCH! I have no experience with the 2430. Hopefully someone will chime in with some assistance.
   / Looking for Help!
Thanks moss road for looking.
Also here are some more spec I found
30hp
0-8mph
12GPM@2500PSI
8 gallon resivor
   / Looking for Help! #4
Go over the entire motor. Any markings? Take a picture. Post the numbers. Pt tends to file numbers off to keep parts I house but they are generally moderately priced off the shelf motors. Still, it won't be cheap. You could look at surplus center and replace all 4m again not cheap but you might find something more powerful but slower,
   / Looking for Help! #5
Also very interested in your use of this machine, how this happened. Any more details or pix?
   / Looking for Help!
Will post more pics of motor when I get home. I looked at suplus a little last night. Only thing about replacing one is the speed. The rock came from the hill behind my house I had tried to move a while ago and couldn't budge it. Freeze and thaw with mother nature moved it without a problem. Here's a couple more pics of the tractor.
   / Looking for Help!
On the use, mostly cleaning out ditch, odd jobs for neighbors, unloading things. More or less its my little helper thats always there, til now.
   / Looking for Help! #8
   / Looking for Help! #9
Double OUCH!
The first pictures didn't look all that bad. It looked like the tractor was sitting next to a rock wall. That last picture shows what I thought was the wall was the rock! We don't got no rocks like that here in South Bend. :eek:
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
14C SCRAPER (A58214)
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
2017 Rogator RG1300B Dry Fertilizer Applicator (A56438)
2017 Rogator...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
