Rotary Cutter looking for guesstimates for how long it would take to clear 2.5 acres of blackberry
   / looking for guesstimates for how long it would take to clear 2.5 acres of blackberry #61
My machine is too big to fit into a 60" wide space. This job sounds like a crew is needed to cut the vines, and a little machine to make them into bits.
A crew is too slow, even at double time, until the tractor arrives.
Bruce
   / looking for guesstimates for how long it would take to clear 2.5 acres of blackberry #62
Here, at about 1:09 to 2:09, is a good view of blackberries and their removal.
Bruce
Easy, satisfying forward bushog work for 30hp or more utility tractor. If only no trellis.
   / looking for guesstimates for how long it would take to clear 2.5 acres of blackberry #63
Bruce
Nice! I'd try it with my PT425.
Now here is the after. I used a small excavator to scrap them, ball them up then grab the ball to pile them up somewhere else. Then used after1.jpgmy tractor with a flail mower to clean up what was left on the ground in between rows.
   / looking for guesstimates for how long it would take to clear 2.5 acres of blackberry #66
That is an amazing transformation!
   / looking for guesstimates for how long it would take to clear 2.5 acres of blackberry #67
Looks good. How long did it take?
Bruce
I started in January and finished last week, working on the weekends.
   / looking for guesstimates for how long it would take to clear 2.5 acres of blackberry #69
Looks good.
Look like a two wheel tractor or small skidsteer w/ a front mounted brush hog (or mulcher) would have have done it quickly.
   / looking for guesstimates for how long it would take to clear 2.5 acres of blackberry #70
2018 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2018 Ford F-550...
24in pin on excavator tooth bucket (A56435)
24in pin on...
Country Line 3 Point 48" Brush Cutter, 540 PTO, Asset# 63 (A59076)
Country Line 3...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
New/Unused Mini Crawler Dump (A57453)
New/Unused Mini...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
