Looking for best quality/price for 48" rotary tiller with adjustable tilling depth
   / Looking for best quality/price for 48" rotary tiller with adjustable tilling depth #11
26hp compact tractor (Mahindra MAX26 XLT HST). Use will be to rip grass from a track around a pasture field and keep track grass free; 5 acre farm so I would consider it to be used for low to moderate duty. Won't have to go deep--maybe 2 or 3 inches max. Soil is clay; not a lot of rocks. Prefer gear driven. Looking at Land Pride RGA1250, Frontier RT3049...wonder about the Ignite 48" rotary tiller.
Looks like the PTO HP on that tractor is 20 and the minimum PTO HP for those tillers is 18. You may not be happy with the performance of both your tractor and the tiller with those tight specs. Perhaps look at tillers with lower PTO HP requirements?
Tilling requires plenty of both weight and HP to be effective...
Good luck with whatever you decide!
   / Looking for best quality/price for 48" rotary tiller with adjustable tilling depth #12
FWIW. Years(late 1950's) ago dad bought a Craftsman tractor-type lawn mower and the roto-tiller attachment. On hard ground the tiller would climb out of the ground and push the little tractor along with the rear wheels off the ground.
He had to plow and disc, before he could use that little tractor N tiller.
   / Looking for best quality/price for 48" rotary tiller with adjustable tilling depth #13
32 wheel drive! That's how the Japanese can till their rice paddies with just 2wd.
Photo I copied from Yanmar-Japan's corporate website long ago:
yanmarinternationalphoto2004-jpg.497435
   / Looking for best quality/price for 48" rotary tiller with adjustable tilling depth #15
I've had good luck with king kutter products. Don't have they're tiller but other items. Rural King sells them. American made in Alabama
   / Looking for best quality/price for 48" rotary tiller with adjustable tilling depth #16
I’m running the Bush Hog RTC50G tiller on a B3200. It requires 15 PTP hp, and my B3200 has 23. It’s gear drive, made in Alabama and has a Chinese gear box. I’ve used it for 4 seasons and have no complaints. You have to be realistic with what you can do when breaking up grass/clay. I started by mowing as short as a could, then set the tiller to about 1 inch just to break through and dislodge rocks near the surface. After a few slow passes, I pick out the larger rocks, then lower the tiller with each subsequent pass until I’m at the 5-6” for my garden. I have never had a problem with it and have no complaints. It pairs well with a B series Kubota.
   / Looking for best quality/price for 48" rotary tiller with adjustable tilling depth #17
I have a land pride tiller for sale. I'm in central/Northern CA
   / Looking for best quality/price for 48" rotary tiller with adjustable tilling depth #18
After much research, I purchased a Tartar brand tiller from Tractor Supply. It's made in the USA but I believe the gearbox is from China. The thing that attracted me to this brand it that you can reverse the mounting of the gearbox and thereby reverse the rotation of the tines. This mean the tiller wants to dig into the ground rather than push the tractor forward and bounce up out of hard ground. Overall, I've been very pleased with the performance. It actually performs better than the heavy Agric brand that served me for 20 some years.
   / Looking for best quality/price for 48" rotary tiller with adjustable tilling depth #19
I understand. But one can spend a lot of money for just a name. As I said in the title looking for best quality/price combo that others have found. Then I can pick what works for my particular application. (I do highly prefer American made, will consider foreign made, but will not buy Chinese made.)
No experience here with chewing up a sod with a tiller, or with working in clay, so I can't say if a tiller would be the best tool for your purpose or not.
That said, less than a month ago we had to replace our 10-year-old 60-inch Tractor Supply tiller because after hitting one too many of our numerous rocks the central shaft broke in two in the middle. We replaced it with another 60-inch tiller from Tractor Supply, purchased on a sale with around $350 off.
Both tillers were made by Tarter. I don't know where the older one was made, but I do remember reading that Tarter had at least one plant in the US where they assembled stuff. The new tiller sported a tag that said it was made in India. The newer tiller is also obviously built heavier. The three-point hitch points are better, can be used by a quick hitch attachment, and can be adjusted to offset the tiller to one side or the other if desired. I can't speak for that shaft that broke on the old one, but the visible frame on the new one is obviously made of thicker metal.
I would not automatically dismiss something that's imported, nor would I automatically assume that everything made in China is inferior.
   / Looking for best quality/price for 48" rotary tiller with adjustable tilling depth #20
My tiller I’m sure is a Chinese tiller, as it was listed in mm, approximately 53.5” in tilling width. I have had it for around 15 years.
Not sure what you plan yo do with the ground once tilled, but a few points from my experience which includes a gray clay locally called gumbo in reclaimed swamp ground from about 100 years near the Mississippi River and red clay in hilly areas.
You do not want to till tall grass or vines. Mow both, shorter is better for tilling. Either gather and remove cut material or allow 7-10 days for it to die. Since you are tilling clay it needs to be mostly dry, but not baked hard dry.
If possible till 1 pass whatever direction, next pass till at 90 degrees if possible, next past at 45 degrees, then opposite 45 degrees. If the clay is too wet it will clump, delay additional passes for several dry days to allow to dry. If you want loose soil, gypsum till in is a must, it may rake applications to get your desired results. You may want to purchase a spreader. If area is not too large, a walk behind or even hand held may be options.
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
Year: 2019 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A56859)
Year: 2019 Make...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2007 FORD F-550 XL SUPER DUTY CHASSIS TRUCK (A58375)
2007 FORD F-550 XL...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
Year: 2023 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2023 Make...
