Looking for a tractor 40-60 HP.
   / Looking for a tractor 40-60 HP. #1
Tkekic
Canfield, Ohio
Massey Ferguson 1648 with a Massey DL130 Loader, Massey 1455v, NH 477 Haybine, NH 268 Hayliner, Pequea Rotary Rake 1140, Pequea Turbo Tedder TT2000, Dixie Cjopper Classic zero turn, Kubota RTV900XT, Woods BB72x 3pt rotary mower, Woods B96 mower
Time to buy a second tractor. Looking at a new Kubota MX 5400HST or a Kioti NS5601.Shuttle. May still look for low hour used. Question. I trust Kubota as I now have L7060 and love it. I was looking at Case/Farmall and was told by a Case dealer that I needed to keep in mind that Case does not make the smaller Farmall line LS does. LS also makes medium range New Holland. Am I wrong not to trust LS. Looks like an old Ford. and from what I can gather has quality issues and is not very reliable. Thoughts and opinions most welcome. Had Massey in the past with mixed results.
   / Looking for a tractor 40-60 HP. #2
CaseIH and New Holland are the same thing, LS is the OEM for CaseNH.
Kubota is my pick if you already are happy with Kubota.
   / Looking for a tractor 40-60 HP. #3
I'm a little confused on your model numbers ...
The best I can figure is you maybe have an L 5060? Or a M 7060 (they just released, or are in the process of a new L6070)
Kioti makes a NS5610 ... Not a NS5601 ...
Curious on why the new tractor would be a MX size? Not a M if you have a Grand L already?
Yes, a MX has a stronger hydraulic lift capacity than an L, but the two are very similar in sizes ... The M is a true utility tractor, if that's what your wanting ...
What are your plans for this new tractor, is it for a different location?
   / Looking for a tractor 40-60 HP. #4
Curious on why the new tractor would be a MX size? Not a M if you have a Grand L already? Shawn T W
my 1st thoughts too. anything less than M utility would be redundant
i once owned MX5000...the MX can't come close to holding a candle to the Utility series, no comparison. purchase wisely, the MX is a compact tractor.
Tractor would be used with the loader, horse manure, gravel (But not often), dirt (again not often) odd lifting jobs. Ted hay, rake hay. I use the M7060 to run the small baler. Second cut brush hog work with 8 footer. Use the M7060 for the heavy brush hog work. three foot+ tall first time in pasture. Push snow when needed. Empty manure spreader. I have looked seriously at 60HP Massey. Very good interest rates.
2018 FREIGHTLINER  CASCADIA (INOPERABLE) (A55745)
2018 FREIGHTLINER...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
DETROIT DIESEL ONE BOX (A55745)
DETROIT DIESEL ONE...
Sunray Family Fisher 17.5 18' Pontoon Boat (A53316)
Sunray Family...
2005 PETERBILT 379 (A53843)
2005 PETERBILT 379...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
