Looking for a roller....
/ Looking for a roller.... #1
jim_wilson
Veteran Member
Northeast MA
Kubota B3200 w/ BH77 & 12", 18" & 24" buckets, Kubota B50 SSQA w/ 54" & 60" buckets, LandPride FDR1660, Artillian Fork frame, Extreme 3pt rake, Concrete Mixer, MyTractorTools grapple adapter
I am currently in the process of using my BX23 to dig out all the roots, stumps, topsoil, and assorted junk the previous owners buried in the yard so my driveway will run to where I plan on building a garage. I have had to dig down about 2 - 2 1/2 feet to get to clay. I will then have to bring in fill to bring the grade back up to where I want the driveway to be. Which leads to my question - I will have a sizable area that I need to compact as I lay the fill down in 6" lifts- it will be approximately 100 feet long and from 11 to 20 feet wide. I have not been able to find any rental places in the area that have the little steam rollers so I have been thinking of getting a lawn roller and using that to do the compacting. Agri-Fab has a 48" and a 36" steel roller. I did some quick math and the 48" if you believe their specs actually has more weight per inch of the roller than the 36" version does. I have been thinking of getting a 48" version and then filling it up with either calcium chloride, beet juice, or cement to get the weight up as high as I can for better compacting. I have also seen the Hoelscher PT roller and that looks like a real nice piece of equipment but the price it at like $1200 which is a bit high for me. I have seen the Agri-Fab 48" roller at Northern Tool for $200. I have thought about building one also but for $200 for the Agri-Fab seems like a pretty good deal. Anybody have any other ideas or know of any other options I should look at? I have a few other rolling projects lined up too so the roller would get used for a few other things than just the driveway.
/ Looking for a roller.... #2
Jim,
The rollers you are mentioning.. are they ordinary lawn rollers that you normally fill with water ?
A few years ago, I've filled mine with sand. This caused the handle at the elbow section (where the roller pins are inserted into the handle) to break after a few hours of usage. My roller was not made for such a weight.
Have you considered renting a compacter ?
/ Looking for a roller.... #3
Jim,
A roller as you described will never do the job that is needed for compacting the fill. You need something much heavier and something with vibration would be even better. Are you putting all stone back? Check with your local asphalt companies, paving companies and stone suppliers. You may find one of them that will rent a roller. There is an asphalt plant near me that rents small rollers, paving machines, dozers, etc to small paving contractors. The little guy can't afford the capital investment but has the labor to move asphalt. Another option is to contract with a paving company to send a guy out with a roller and run it for the day. I know you probably want to do the job yourself at your own pace to save $ but you may be surprised (pleasantly) at the cost of hiring someone to bring in the stone, doze it and roll/compact it. Probably less than a days work.
Jeff
The rollers I was looking at are the ones you see at Northern Tool that fill with water. I know the instructions I read said that if you fill them with sand they should only be filled halfway. You probably had one of the same ones I was looking at. Sounds like my idea of filling it with cement probably wouldn't work. I will have to look around a little more and see if anybody rents out the small pavement rollers. One of the reasons I was trying to avoid renting is that I think it is probably going to take me at least a couple of days to fill in the area I have excavated and bring it back up to grade. This would mean at least a couple of days of rentals and I bet the rental fee on a pavement roller around here (northeast MA. ) is probably at least $150 a day. Then I also have other projects where I am going to have to do some compacting so I figured buying a roller to do all these jobs would make sense moneywise spread over all the jobs I had to do.
Would one of the vibratory compactors be a good option to use? I think I know somebody who has one of these that I might be able to borrow. I know it would take longer than using a pavement roller but free is free. I was looking at some specs online and they were claiming that they generate like 3000 pounds of compaction force etc. That seems like a lot more than one of the small pavement rollers would generate.
/ Looking for a roller.... #6
http://www.bomag.com/worldwide/index.aspx?fm=%2fconstruction_machineries%2f0E13C8CC390C44DABE3BA1E4B8F3F2F7.aspx&DID=100000000&Lang=10000
This is a link for a size/type compactor that would do that size project. This should be available at a Modern or United rental shop. Something this size would warrant a second person to roll while you place fill, but you'd be surprised how productive it can be. I don't think much larger of a roller would be cost effective.
Vibratory compaction is required for soils in most conditions. Depending on the soil your filling with you should be able to go to a 12-16" lift with no problem.
Also, some of the trench rollers I'm talking about come with wireless remotes. Theoretically, you could do the whole job yourself without ever leaving your tractor seat.
/ Looking for a roller.... #7
That link isn't working right. Click on products > light equipment > multipurpose compactors.
/ Looking for a roller.... #8
I looked for a "real" lawn roller for a long time. It doesn't appear to be an item that is mass produced by anyone at this time. I found a welding shop in upstate NY that makes them and a bout a 72" model. It's built like a tank and weighs 1600# loaded with water and appears to be undentable after 2 years use.
www.gwfab.com
Cool - that is what I was looking for. How much did this cost? I downloaded their catalog and noticed that they make a number of different widths.
/ Looking for a roller.... #10
Jim,
Do a little research on soil compaction and you will probably find that vibration does not help with clay.
So far I have built 3 buildings with cement floors on compacted red clay fill. I put it down in 6 inch lifts and compacted it with the tractor wheels, with the FEL full of dirt. Those small front tires with all that FEL weight exert a lot of pressure. Back and forth, in both directions if you can. If the clay is too wet, it just mushes sideways. If its too dry, its so hard that you wonder if its just compacting a thin top layer.
On top the compacted clay is a layer of crushed limestone. No floor cracks, except at the ends of the saw cuts, where its supposed to crack.
The attachment is the pad for a 36 X 53 pole barn. Note all the tire tracks.
John
ps If that clay is not well drained, I'm not sure if it matters how you compact it. In my cases, its always going to be dry.
The places where I have finished digging down thru the topsoil I believe I have hit a sandy clay. When it is dry it has a sort of clumpy sandy consistency. I find when digging with the FEL on this layer the rear wheels will just dig themselves a hole if I try really pushing into a bank with the tractor. We had about 2 days of rain here from the remains of the hurricanes going thru New England on their way north and I went out tonite and did some digging and found that when this clayey soil was wet it compacted down pretty good and I got much more traction on it with the tractor when I was digging with the FEL. I am not too worried about compacting the layer I have dug down to since I think it is probably pretty compacted already - I am more worried about compacting the 2 to 2 1/2 feet I will have to lay down to bring the grade back up to where I want the driveway to be. I have had a number of suggestions on what to use as fill and the best option seemed to be the rock dust and 3/4 stone. I know this is commonly used for a base when patios and brick driveways are laid so I figured it would be good for a asphalt driveway also. Once I have this filled it will be sitting for probably a year or two before it finally gets paved.
/ Looking for a roller.... #13
If you are filling with a stone dust/stone mix then letting it sit for a year or more compact it with your tractor in 6" lifts. A year of rain and driving on it will take care of the rest of the compacting. Also when it comes time to bring in the paving company they will flatten and roll the base again. I’d save my money on this round.
MarkV
/ Looking for a roller.... #14
TSC sells a 48" roller for under a hundred bucks.. or they did last year.
Make sure you don't get something too heavy for the bx to pull.
Try a sod company.. they use small rollers ( sod roller ) when putting down sod.
That said.. if you have a heavy implement on your tractor.. simply running back and forth will compact it. The surface area at ground contact on that tractor is small.. and the weight is decent.. that figures out to some good psi ratios.
I've compacted building pads using a pan filled with dirt.. simply rolling over and over it..
They also make small vibratory culdepackers.. Perhaps one of these 3 options will work for you.
Soundguy
/ Looking for a roller.... #15
</font><font color="blue" class="small">( ...This would mean at least a couple of days of rentals and I bet the rental fee on a pavement roller around here (northeast MA. ) is probably at least $150 a day. Then I also have other projects where I am going to have to do some compacting so I figured buying a roller to do all these jobs would make sense moneywise spread over all the jobs I had to do. )</font>
Day rates on rentals suck. You might want to check out the weekly, or even monthly rate. The longer you rent, the better the break.
I just checked my "Rentals Unlimited" Catalog they have a Double drum Vibratory Roller (walk behind) that rents for $110/day or $385/week.
Here's another example, I once rented a flooring nailer for a month @ $60/ month, The day rate was $30/day. I didn't use it for the whole month so I got credited back about $10.
/ Looking for a roller.... #16
Rollers are for smoothing, and won't help much.
Tractors are under-rated as compactors.
A CUT with the loader full of dirt and a heavy implement on the back (loaded tires help too!) is a much more effective packer than any roller. If the soil moisture is just right, the wheels can pack it very effectively.
Doing a 20x100' drive wouldn't take no time at all with 16-24" wide tires.
I was wondering if I might just be best off using the tractor to do the compacting. It is a BX23 so it is not the heaviest tractor but the rear tires are loaded with beet juice and I have 600+ pound backhoe attachment hanging off the back. There has to be a good 900 -1000 pounds on the rear wheels.
/ Looking for a roller.... #19
Figure that with your tire footprint and that is a decent load. Like I said.. I've compacted without rollers.. and just used equipment driven over and over an area..
Soundguy
/ Looking for a roller.... #20
</font><font color="blue" class="small">( Figure that with your tire footprint and that is a decent load. Like I said.. I've compacted without rollers.. and just used equipment driven over and over an area..Soundguy )</font>
I wouldn't compact with tractor tires for state highway construction or a home foundation, but it's just fine for a driveway. In fact, A heavy little CUT can be better than a big dozer for packing. My little TC29 was better than my TC35 for packing. As you say, it's the PSI that counts.
UNUSED KJ 11'X19' ALL-STEEL CARPORT (A62131)
UNUSED KJ 11'X19'...
2009 Mack GU813 Roll off Truck, VIN # 1M2AX13C59M007359 (A61165)
2009 Mack GU813...
2019 Isuzu NPR Box Truck, VIN # JALC4W169K7009134 (A61165)
2019 Isuzu NPR Box...
30 Yard Roll Off Dumpster (A61166)
30 Yard Roll Off...
UNUSED KJ HD 5'HX5.6'L WIRE MESH (3 PANELS) (A62131)
UNUSED KJ HD...
MASSEY FERGUSON 231 TRACTOR (A62130)
MASSEY FERGUSON...
