Rotary Cutter Looking for a New Brush Cutter
   / Looking for a New Brush Cutter #21
Farmwithjunk said:
I use my BB840 behind a 60 (+) HP 2440 Deere.(6 suitecase weights and weight bracket on front too) It's more a matter of handling the WEIGHT than HP to turn the blades. It's somewhere in the 1400lb range. 7' mowers extend back so far from the tractor, that weight is amplified. Takes a HEAVY tractor to use a BB840.
Does it not have tail wheels to take some of that weight?
Soundguy
   / Looking for a New Brush Cutter #22
john_bud said:
Sure! I will pull any attachment that does the job. Sorry to break the secret, but not all "branded" attachments are made by the company with the name of the side....shhhh....
jb
Uhh, was that the soft rustle of rope sliding over a tree branch?
I pull a jd 1517 batwing behind my NH 7610s... havn't been hit with any tomatoes yet...
Soundguy
   / Looking for a New Brush Cutter #23
Soundguy
Yep.....When they're on the ground. That Woods BB840 is stretched out a good bit behind the tractor. In addition to being heavy, the weight is far enough back to get that dreaded leverage. Also, the 2440 is short wheelbase for the weight of the tractor. It's a lot safer with all the weights.
MF 150 with an 1100 lb mower will keep th efront end glued to the ground with no more than a brush guard on it's front end.
3000 Ford with same mower needs front weights.
   / Looking for a New Brush Cutter #24
You don't have the mower off the ground alot do you?
My 10' 3pt mower stays on the ground unless I'm clearing an obstacle...
Soundguy
   / Looking for a New Brush Cutter #25
When we were at the old place, I needed to run up and down a county road quite a bit. At low speeds, while mowing, I don't get much front wheel bounce. At 20 MPH going down a rough road, it was "Joey Chitwood" stuff sometimes without the weights.
Isn't that 10" Howse a double-spindle mower? The Woods BB840 is a single. That pushes the weight back a few more feet, compounding the problem.
One more issue. We have a lot of hilly ground here. Going up a hill with a heavy mower on the back end will make about any tractor have a tendency to lift the front wheels.
AND... There's a creek running through the new place. I have to back out over the bank, lower the mower, and pull forward to mow some of it. Kind of a "cheap thrill" when the mower is 10' off the creek bed and the front end starts getting light.
Lastly, the 2440 is light on the front end without weights. I'm contemplating buying a new loader, as the one I have for the 3000 Ford is from the Flintstone era. The 2440 would benefit greatly from the weight of a loader. Not to mention I'd have a better set-up with the loader on a more powerful tractor)
   / Looking for a New Brush Cutter #26
"There's a creek running through the new place. I have to back out over the bank, lower the mower, and pull forward to mow some of it. Kind of a "cheap thrill" when the mower is 10' off the creek bed and the front end starts getting light."
That right there is what I call pucker factor. If you try and move the tractor forward the front end is lighter yet. Ugh, plus the blades spinning it would be like falling into a blender.
   / Looking for a New Brush Cutter #27
You are missing my point entirely.... If the mower has tail wheels... the weight is divided between the tail wheels and the lower draft links.. I.E... if the tail wheels are on the ground.. the front end ain't coming up.. unless the mower is just too plain heavy for the tractor, and the fact that it is hitched makes the front end come up. IMHO.. if that is the case.. the tractor is too small for the duties.
All of the situations you illustrate below should only come into play if the tail wheel is not on the ground.. thus making the tractor carry the entire load...
How much does that BB840 weigh?
Again.. going up a hill with a heavy moer on back should not be an issue IF.. the tail wheel(s) are on the ground, dividing the weight the rear of the tractor sees. Imagine a person standing on either side of a heavy box and both lifting.. each person only percieves a portion of the weight... Now.. take one person , and lift that load from one side.. that person percieves the whole weight.. plus has mechanical advantage against him as he is lifting from one edge and ALL the weight is away from him... Same issue here... with tailwheels onthe ground.. you have '2 people' carrying the weight..
Soundguy
   / Looking for a New Brush Cutter #28
I'm having a hard time picturing this geometry. The mower deck is 10' off the ground.. yet it can be lowered far enough to mow the bank... That sure is some huge amount of swing on that toplink.. and I'll bet there is a huge angle on the u-joints too... Sounds foolish.. if at all possible, given the variables mentioned.
Soundguy
   / Looking for a New Brush Cutter #29
Soundguy
Not missing any point, entirely or not.
I'm weighting the tractor for carring the mower RAISED. My 3000 Ford could lug the mower around with the tailwheel ALWAYS on the ground. I'm not running around on a square, flat field. Most of the TIME SPENT mowing for me is cleaning up around the edges of a woods, a creek bank, and a couple hillsides. While I'm on those hills, I have to turn around in a couple rocky areas. That DEMANDS raising the mower and it's tailwheel off the ground. I'm cutting around rock edges of a creek bank. I HAVE to hold the weight of the mower off the ground because sometimes the tailwheel is 8 or 10' in the air when sticking over the bank.
In short, I'm not mowing the same way you are., I have to set up things so they're safe and able to get a job done.
The BB840, with chain gaurds front and back, along with double tail wheels
is a tad over 1500 lbs. The tractor EASILY handle 2500 lb loads on the hitch. NOT when backing over banks, turning on steep hillsides with the mower raised, or a great deal of the mowing it has to do. At least not 100% safe, 100% of the time.
The 2440 weighs in at 7400lbs, weights, fluid, ROPS, ect incl. It isn't overloaded, not even close. (Cousin had a 2440 too. He ran a 10' 3-point mower (on more reasonably "flat ground"))
   / Looking for a New Brush Cutter #30
Soundguy
Sounds foolish or is PERCIEVED as foolish by someone who doesn't have a very good picture of what's actually happening?
The mower isn't dropping 10'. It just ends up stuck over the edge of a 10' drop into a creek bank.
Simply because you don't understand something doesn't make it wrong.
   / Looking for a New Brush Cutter #31
Reading your previous posts, it sure looked like you were saying that the mower was going to be more up than down. With this last post, it sounds like the mower is down 95% of the time, and then raised to maneuver around obstacles. That's 2 entirely different scenerieos, and was what I was refering to. It is probably easier to make the mower stable enough for intermittant pickups, vs running full up while being transported..
My ford 5000 easilly picks up my 10'mower weight wise, but I had to hand 420# on the front as it really unloads the front end. As it is now.. I feel 100% comfortable about mowing with it down, and also moving the tractor at mowing speeds with it raised up. I would not run it at transport speeds with it raised up unless I added another 300 pounds or so up front. My 7610s could transport it raised fine.. but is a tad heavier, plus has 640 pounds of weight up front. Those few hundred pounds make a difference in raising at mowing speed, and raising at trasnport speed... that's the point I was trying to make...
That is.. do you really need the extra ballast on the tractor ? it adds to soil compaction, fuel usage, and bearing loads. That's why i try to get away with a good safe counterballance, even if doubling the weight might get me another few percent safety, vs lower efficience int he pasture, damage to the pasture, and wear and tear on the tractor.
Soundguy
   / Looking for a New Brush Cutter #32
I'm not seeking "a few percent safer". It needs to be weighted for the "worst case" portion of the job, The "best case" portions are a breeze. (Most of the place is relatively flat.) On that other 5 or 10%, the mower ends up being a giant "weed eater". A lot of backing over ledges and banks with the mower raised. While doing so, I'm on hillsides. I'm not going to take weights off and put them on every time I switch from one condition to the next. As far as possible damage to the machine, in view of the fact these weights have been on the 2440 since I bought it, in 1978, and there's been no signs of premature wear, I'd say the tractor can handle those weights jusy fine. (Would wear in 28 years use be considered "premature"?)
   / Looking for a New Brush Cutter #33
IMHO.. you are practicing unsafe mowing practices.. mowong on hillsides, with mower raised, ditches.. etc.
As for weight adding wear.. it's a scientific fact... The more load the tractor totes.. the more it wears.. can't beat physics unless you are 'scotty'.
As I say to most people bent on doing something.. "go ahead".
Soundguy
   / Looking for a New Brush Cutter #34
Soundguy
"IMHO", Hmmmm. Looks like your opinion is for the most part, WORTHLESS. How many THOUSANDS of us do you suppose need to mow on hilly ground? How many of us mow on rocky ground? You think I'm the only person who's ever mowed a ditch bank? Stepping on a lot of toes with that ridiculous "opinion".
Just about every farmer I've known has added front weights to their tractors. Every major manufacturer includes front weight brackets and weights as options on their products. In all the cases I've seen, these tractors are designed and built to accomodate those weights. Sure, they might cause some wear, maybe even enough to measure in a lifetime. But if they weren't supposed to be on the tractor in the first place, don't you suppose the folks at John Deere, Ford, Massey Ferguson, Case, Oliver, Allis Chalmers, ect, ect,.... would have NOT RECOMMENDED them as ballast? Too bad they made such a grievious error. Glad you came along and saved us all from ourselves.
After spending a long, SAFE lifetime doing what I do, I'm sure glad I now have your blessing to "go ahead".
   / Looking for a New Brush Cutter #35
Soundguy
I use and transport my 12' Bush Hog brush cutter (For Sale) without any weights up front. At first I thought it was because of having the loader up front, but have taken it off and no "wheelies". I was kinda shocked that I have enough weight up front to transport in road gear!!
RedDog
   / Looking for a New Brush Cutter #36
Is that a 3pt mower.. or a drag mower. if a drag mower.. it's no big deal.. if it's a 3pt mower.. when it is raised .. that's where the front weight comes in.. ( drag mowers always have wheels ont he ground.. 3pt doesn't always.. )
Soundguy
   / Looking for a New Brush Cutter #38
Wow.. I don't think I've ever seen a 3pt 12' mower.. got any pics. Who makes it? model #? Age?
Is this a finish mower? or rough cutter, and is full 3pt or semi-mount?
2 spindle, or 3 spindles? front to rear length, and weight?
thanks
Soundguy
Soundguy
   / Looking for a New Brush Cutter #39
thanks
Soundguy
Soundguy
Make is Bush Hog. I have it down by the road right now with a For Sale sign on it, and I know it has a tag on it, but I'm to lazy to go down there and read it. Not sure of the age.
We have always called it a "brush-hog". It has 3 gear boxes. Not sure of the front to rear length or the weight. I can pick it up with my loader and pallet forks and not have the rear of my tractor come up. This is with nothing on the rear.
I'll see if I can get this picture up.
RedDog
   / Looking for a New Brush Cutter #40
RoyJackson said:
I have a Land Pride 60" cutter which I've run pretty darn hard. It's dented up a bit (rocks and stumps), but cuts (pulverizes?) like a champ...therefore, I can recommend Land Pride cutters.
A 60" cutter (standard duty...which is probably all you need) costs about $1100.00.
Agreed, i have a landpride 15 series, very happy with this unit.
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A59230)
2019 Ford F-350...
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
SCAN TO RECEIVE TEXT UPDATES (A60430)
SCAN TO RECEIVE...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A61307)
Case Wheels for...
2019 TAKEUCHI TL8 SKID STEER (A60429)
2019 TAKEUCHI TL8...
