Looking for a fan to mount to my rops
   / Looking for a fan to mount to my rops #1
nod
Have a Mahindra tractor that I finally got a fiberglass top for. Looking for a fan to mount behind the seat on the rops to try to keep me cool in this miserable weather. Has anyone done this and if so can you tell me what you used. I'm thinking about a 12volt car fan. Thanks for any help.
   / Looking for a fan to mount to my rops #2
I mounted a 12V radiator fan just under my canopy and it blows downward. It works pretty good. I would suggest mounting the center of the fan slightly in front of your head when sitting in the seat. I will post a picture in a day or two.
   / Looking for a fan to mount to my rops #3
I had one on a tractor with canopy a few years back. Also had one in open cab of excavator. Did help. Bought mine from NAPA.
That would be great, thanks.
   / Looking for a fan to mount to my rops #6
We mounted a 12 volt car radiator fan on our zero turn mower. It is great. We mounted ours to blow on the back of our neck and head. Helps some on keeping clean air to breath also.
   / Looking for a fan to mount to my rops #7
Do search for ROPs mounted fan, you should fine several ideas. Something like this works good. IMG_0388.JPG
   / Looking for a fan to mount to my rops #8
tractor supply had them on the shelf today
   / Looking for a fan to mount to my rops #9
Consider 12 volt muffin fans, very efficient and compact plus draw very little current.
I have 2 mounted in my cab and even the deer flies can't enter to bite me.
Generally they came in about 4" X 4" (1" thick) size.
Also very quiet.
Mine are on a swivel base so in winter they serve to defrost while in summer they keep me cool.
To mount on a ROPS you could use simple hose clamps (the type with rubber sleeves)
   / Looking for a fan to mount to my rops #10
depends on what you want...12-Volt Heavy Duty Metal Fan by RoadPro If mounting underneath canopy...https://www.oreillyauto.com/shop/b/...c-radiator-fan---universal-17446/f68f3e18e7da
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2015 FREIGHTLINER...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
2015 Kia Sedona Van (A50324)
2015 Kia Sedona...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
2008 FREIGHTLINER B2 BUS CHASSIS (A52576)
2008 FREIGHTLINER...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-150...
