looking for a 5ft Brush hog
/ looking for a 5ft Brush hog #1
gippolit
New Jersey
CK30HST Loader Backhoe
I don't have much money to spend I was looking at a king cutter. Is this a good hog? I've also looked at the Rhino, but it's at 1400 bucks.
/ looking for a 5ft Brush hog #2
/ looking for a 5ft Brush hog #3
Just saw it in the newpaper, TSC is selling a 5' King Kutter for $613......... /forums/images/graemlins/cool.gif
/ looking for a 5ft Brush hog #4
$1400 sounds outrageous for a '5 cutter.
I paid $500 3 years ago for a 4' cutter, Fred Crain Agri-Cutter 104. It's built like a tank and uses the same gearbox and I believe blades as Bush Hog brand cutters.
Now, I'm not sure if they are available in Jersey but I'm sure you could have one shipped there for under $1400.
/ looking for a 5ft Brush hog #5
What will you be cutting with it; a weedy meadow or 3" diameter saplings? Are there rocks, stumps or other junk is the area, or is it clear of damaging obstacles? How many hours/acres per year do you plan on cutting with it?
I've looked at the light duty King Kutter at Tractor supply and they look like they'll last years cutting a weedy meadow. But I don't think they would last a season used on 7 year old clear cut regrowth. Not everyone needs the most rugged cutter available, but if they do anything less will be turned into scrap metal pretty quickly.
/ looking for a 5ft Brush hog #6
I'm in my 4th year of using a 5' KK I bought for 200 bucks used. I'm planning to upgrade to a higher quality 6' cutter, but the KK just keeps hanging in there even through work that's really too rough for it. The KK is a low buck unit and won't have the quality or durability of the more expensive major brands, but it will do a reasonable job and is a lot lighter on the wallet.
/ looking for a 5ft Brush hog #7
I've been cutting saplings up to 2" with a 5' KK from TSC. Works fine and it was cheap and convenient.
/ looking for a 5ft Brush hog #8
In my opinion the King Kutter would be all you need.
Cleared my property with a 6' KK w/slipclutch. Hit many dirt piles, found several bricks with the cutter, a couple cement blocks, Etc. Worked fine , no damage.
/ looking for a 5ft Brush hog #9
I just purchased the Rhino TW60 yesterday. It is definitely heavy duty. It seems steel surcharges are still pushing these things upward. I got the following prices in Georgia. The Rhino lighter duty model SE5 was $1195 which seems heavier than the Bush hog model which I received a price of $895. The heavy duty models are almost 300 lbs heavier but generally $400 more expensive. I like the idea of cutting down small trees /forums/images/graemlins/smile.gif.
/ looking for a 5ft Brush hog #10
Howse or KK.. whichever is cheaper.
I've been using my 5; KK for almost 5ys now.. it's got a scratch or two.. but that's it.
Soundguy
/ looking for a 5ft Brush hog #11
I had a King Kutter for years and as far as I am concerned you get good value for your money.
/ looking for a 5ft Brush hog #12
I bought a new 5' Bush Hog Squealer SQ600 in February. Love the cutter. VERY TOUGH. Only paid $890.00 total. I am in Louisiana.
Travis
(INOP) WHITE 2-180 TRACTOR (A63291)
(INOP) WHITE 2-180...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
Katolight SED60FJJ4 75kVA Towable Diesel Generator (A61572)
Katolight...
2007 International 4300 Cab & Chassis 438418 (A62613)
2007 International...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A62130)
2001...
Generator (A61572)
Generator (A61572)
