Backhoe Looking for a 36" ish Ditching Bucket for LB1100 series Backhoe
   / Looking for a 36" ish Ditching Bucket for LB1100 series Backhoe #1
46chevy
Fordson
I have an XG3135 with 1100 series backhoe. Looking to replace bucket with a 36"ish wide Ditching bucket...essentially to clear off sod.
Anybody know where to source one or Pin size and spacing for the LS backhoe buckets.
Thank much
   / Looking for a 36" ish Ditching Bucket for LB1100 series Backhoe #2
It's a 25MM x 195.5 Long Pin with grease fitting - so 1" x 8" long and you will need to measure between your bucket ears for width and between the pins to get the pitch.
Probably around 4" between ears, and 5 to 6" center to center pins.
   / Looking for a 36" ish Ditching Bucket for LB1100 series Backhoe #3
You probably want one that is fairly small/shallow. 36" is a lot on a standard backhoe and fully loaded, can shift your centervof gravity quickly if you swing too fast
   / Looking for a 36" ish Ditching Bucket for LB1100 series Backhoe #4
LS lists a 36" bucket for the 1100 BH, and the 35HP tractor with FEL and BH is at least 4500 lbs so should handle this bucket.
I dig and lift rocks 300LB + and lift logs - 7-800lbs to cut them up and or carry them with my little TLB BH without issue. It weighs 4000Lb with digging bucket force of 3500Lbs.
Thanks Much Carl_NH. Much Appreciated!
2009 FREIGHTLINER CASCADIA (A58214)
2009 FREIGHTLINER...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2014 Transcraft Trailer (A55973)
2014 Transcraft...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
CAST IRON POT (A58374)
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
