Looking at side by sides?
/ Looking at side by sides? #1
tomfifield
Eagle creek Or
Kubota 3400
I am most likely going to get a used one, what are my best choices? It needs to be a 4x4, I do not care about speed as much as how well it climbs. I will use it to travel around my roads for the most part. I have been looking on Craig's List and Ebay to get an idea of what is out there. Is there anything I need to look out for? What should I be looking at for features? Are any built better than others?
/ Looking at side by sides? #2
There are a lot of side X sides out there and most will do what you want. You need to decide what you will be doing on it. If you plan to carry large loads in the bed then Polaris has a good size bed. I have a Yamaha Rhino and it works out for me. We ride trails that the Polaris can't go on due to width of the unit. Mine is not the fastest but it will run 42mph if needed and will climb very well.
Mostly I just want to travel around my land, and maybe ride trails. I use the tractor and a trailer to haul stuff. Thanks.
/ Looking at side by sides? #4
Polaris Ranger 400, midsize
/ Looking at side by sides? #5
If you are at a high elevation get the fuel injected Polaris. Also great for the cold weather starts.
/ Looking at side by sides? #6
My neighbors farm has a Polaris Ranger 800 and is very happy with it.
/ Looking at side by sides? #7
Kubota RTV...love mine...excellent all the way around. Reliable. Top speed around 24 MPH but unstoppable in the pasture.
Look for extra features ...windshield, winch, etc...WATCH OUT for scams on Craig's List, elsewhere...buy used only local and after driving the unit.
/ Looking at side by sides? #8
If you're looking for used, and a great value, I'd suggest you look for a Yamaha Rhino 450. A used one will likely not have been "hot-rodded" like the Rhino 660s and 700s might have been. Yamaha essentially "invented" the sport/utility side-by-side and are high quality, very dependable machines if used like they were originally intended.
IMO, two features are absolutely essential: (1) a locking front differential - though not frequently needed, when you really need it, it can mean the difference of driving out under your own power or being winched or pulled out, and (2) engine braking for safely and slowly going down steeper grades or slopes - earlier models of many brands did NOT feature this.
Yamaha is getting ready to announce new models this month supposedly, and the price of used machines will likely be even more reasonable...
/ Looking at side by sides? #9
I have a Rhino 700 and my vote would be for a Rhino. A few things about them I don't like. I have changed the stator once....it fried. And the rear differential.....get a aftermarket bracket.
But as far as Yamaha making an announcement.....I will believe it when it happens...lol
/ Looking at side by sides? #11
/ Looking at side by sides? #12
I have a 2006 450 Rhino,3200+miles ,one set of tires and change the oil/filter in the spring.Use mine about every day.
/ Looking at side by sides? #13
I'd suggest a mid-size Polaris if you want a narrow vehicle that can fit through tighter trails. Either a 400 or 500. Look for a 500 w/EFI if you run at varying or just high altitudes. Note that 2006 and older 500s are full-size. The 500 is very reliable engine.
/ Looking at side by sides? #14
Well, Yamaha's new product announce is later today. We'll soon know what they've come up with. Rumors about -- everything from a 3 or 4 seater to a sport model...
Knowing Yamaha, it will likely be fairly conservative (i.e. not radical) and thoroughly tested...
2015 PETERBILT 579 TRI/A DUMP TRUCK (A59914)
2015 PETERBILT 579...
Bobcat Pallet Forks (A64127)
Bobcat Pallet...
208735 (A60430)
208735 (A60430)
Landhonor Quick Attach Seeder (A66285)
Landhonor Quick...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
2014 FORD F350 4X2 S/A DUMP TRUCK (A59914)
2014 FORD F350 4X2...
