Looking at JD 2210, 4010
   / Looking at JD 2210, 4010 #31
I looked at the 2210, 4010, 4110,and 4115 before purchasing a 4010 w/ a MMM and FEL 6 months ago. I think your choice should be based on what you are going to use the machine for rather than what everyone else says. I mow 2.5 acres of lawn, grade hundreds of feet of driveway, and am slowing removing trees from another 2.5 acres. I needed extra ground clearance for clearing in forested areas and I needed light enough weight to be able to drive on the lawn without sinking with the Western WA dampness. The 4010 met my requirements and I have had no problems with it. With the HP limitations I have had to take a little more time when digging and pulling stumps, but it has had adequate power for pretty much everything I've done. Another option for me would have been to buy a larger tractor and a separate riding lawnmower, but my decision saved some money and the 4010 has worked well with no limitations. I also plan to dig hundreds of feet of drain and may purchase a small backhoe. There has been much bantering about the inadequate structure of the 4010 in supporting a backhoe, but there are aftermarket versions for 18 HP tractors that work well for light digging work and my JD Dealer will order, install, and warranty a unit on the 4010. I felt that with my terrain, a little more ground clearance would help in this respect as well. I hope this helps a bit.
2014 Landoll VT-Plus (A52349)
2014 Landoll...
71069 (A49346)
71069 (A49346)
2014 Nissan Maxima Sedan (A50324)
2014 Nissan Maxima...
2013 VOLVO VNL860 TANDEM AXLE SLEEPER (A51219)
2013 VOLVO VNL860...
Agway Bale Accumulator (A50515)
Agway Bale...
CATERPILLAR 325FL CR EXCAVATOR (A51242)
CATERPILLAR 325FL...
