looking at a new acquisition
/ looking at a new acquisition
My dad gave me a start with mechanical things by owning tools and letting me use them. He was out for a visit recently and we were working on an old 8n...even at my age (early 40s) it still feels good when he says " you're a good mechanic"...thanks dad I own some of it to you.
/ looking at a new acquisition #22
The S370 & G154/174 both use the double knuckles. The ST1440, MT372d, & Yanmars uses bevel gears . A much better design. The axle shaft ( pn 11190672000) on the S370D is a weak link. I get quite a few calls on them. They are no longer available from Mitsubishi, but have some used & am making ones that are heavier & cheaper than the OEM one.
/ looking at a new acquisition #23
Technically, the G154/174s use a double yoke and single cross design, while the Satoh's use a double yoke, double cross according to the information I have. You can see the Satoh's here:
Satoh Parts
The Iseki skips the cross coupler and uses one cross.
I'm not trying to point out mistakes, just pointing out that the axles are not identical in design. Some people have asked that before and I just want to clarify it here also.
/ looking at a new acquisition #24
Your correct. I didn't stop to think before I posted that info. I should have said they both use ujoint assemblies.
/ looking at a new acquisition #25
Anybody got one of the these axles lying around for parts? I just found out I have a broken final drive case on one of the wheels (ouch). I can't believe it actually worked like this w/o showing some sign of failure. Another reason you need to be careful having a FEL - yikes! Hope you don't mind me "borrowing" your pictures 284 but I couldn't have taken better ones myself :thumbsup:
/ looking at a new acquisition #26
Is that off of your Iseki, or Satoh? There is a guy parting out an Bolens G154 on eBay right now, and probably has a final drive. I can give you the link to it. You could try these guys if its a Satoh. Judging by the blue paint, I think that it may be.
This guy has the G154/TX1300 parts tractor, you could email him:
http://www.ebay.com/sch/m.html?item...=item2ebdad3d7b&_ssn=joes_outdoor_power&rt=nc
or if its a Satoh?
http://www.satohparts.com/
This might be what you need? http://www.ebay.com/itm/SATOH-BEAVE...pt=Tractors&hash=item2c5058a41b#ht_500wt_1005
or this?
http://stores.ebay.com/Rigentinc-Cycle-Salvage/_i.html?_fsub=5918922
/ looking at a new acquisition #28
Thanks for the help NHMitch. Sorry, I should have stated it is off a Satoh S373D front axle. I should have posted in the Satoh forum, but this thread kind of was heading in this direction. I'll check out the links. Thanks again!
/ looking at a new acquisition #29
joes outdoor power | eBay
or if its a Satoh?
Valley Power
This might be what you need? SATOH BEAVER S370D RIGHT FRONT END WHEEL GEAR CASE | eBay
or this?
SATOH BEAVER S370D HYDRAULIC SUCTION INLET TUBE LINE items in Rigentinc Cycle Salvage store on eBay!
Those are all good links. Unfortunately, the S373D front 4wd axle is much different than the S370/2 fronts which some of those links point to. Attached is a parts list showing what I need. Appreciate the help!
Thanks for the feedback guys, sounds like a good starting point for a project...I'll let you know if I manage to pick it up...lots of irons in the fire right now.
/ looking at a new acquisition #31
I'll keep an eye out and see what i can find, you never know what someone will sell on eBay from day to day.
/ looking at a new acquisition #32
I have front end parts but I don't see what is broken.
/ looking at a new acquisition #33
The boss the bearing fits into on the final drive housing is broken from about 7 o'clock to about 5 o'clock. Also the pinion is mostly gone on the bottom of the picture.
1999 Yamaha 350 Big Bear 4-Wheeler (A66408)
1999 Yamaha 350...
Crane (A64194)
Crane (A64194)
2022 EZ-GO ELITE...
John Deere 757 ZTrak Zero Turn Mower (A66285)
John Deere 757...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A64280)
2001...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
