Looking at a hydraulic offset flail for the 3038e -It's Home!
   / Looking at a hydraulic offset flail for the 3038e -It's Home! #11
For anyone interested, I found a pretty complete list of specifications on the Frontier FL1061S flail.
FL1061S - 61" FLAIL MOWER (SIDE OFFSET) Product Features
Dimensions
Capacity, Cutting (in.): 0.79"
Height, Cutting (in.): .78" /1.57" /2.36"
Height, Overall (in.): 38.7"
Length, Overall (in.): 71.2"
Width, Cutting (in): 61"
Width, Overall (in.): 68.88"
Weight (lbs.): 663 lbs.
Compatibility
Tractor HP Required (min. - max.): 25 - 45HP
Tractor Weight MINIMUM (lbs.): 2600 lbs.
COG (in): 45.6"
Hitch
Hitch Type: 3-point
iMatch Compatible: No
Hitch Category: 1
Hitch Position: Offset
Offset Range: Left of Center (21.5"), Fully Extended - (83")
Hydraulic Offset: Standard
Blades
Blade Type: Hammers (std); Y-Blade (service)
Number of Hammers: 32
Type of Blades/ Hammers: 19 / 21
Blade Tip Speed (ft/min): 8622
Rotor
Rotor Diameter (in.): 5"
Rotor Speed (rpm): 2600 rpm
Rotor Thickness (mm.): 8 mm.
Rotor Work Diameter (in.): 12.63"
Rotor Bearing Type: SPHERICAL ROLLER 22207
Drives
Gear Box Speed (rpm): 540 rpm
Drive Belts: 2 - SPB Lp=1160
Gauge Roller Diameter (in.): 5.5"
Other
Hydraulic Quick Coupler Size (in.): 1/2"
Frame Thickness (mm.): 3 mm.
Side Frame Thickness (mm.): 4 mm.
Roller Bearing Diameter (in): 2.4"
Rear Roller Bearing Type: D30 D62 B20 2206E 2RS1
Belt adjustment: Screw adjustment
Primary Pulley Diameter (mm.): 225 mm.
Secondary Pulley Diameter (mm.): 140 mm.
Hood Height (in.): 15.35"
Side Case Height (in.): 25.2"
PTO Yoke Height (in.): 19.29"
When the specs list "offset range" ,, does fully extended - (83") mean it will offset to the right that far? The whole thing exteneds outside of the right wheel?
Will your 3038e need wheel weights on the left wheel?
I believe that is 83" from the centerline. Nominal width of the 3938e is 60", so 83 - 30 = 53" beyond the red wheel. That's my interpretation anyway.
Interim update...
The Fasse multiplier is in and a FL1061S was located in network & rerouted to my dealer. They are still working at locating the correct vintage JD scv kit for my 2010 3038e. Looks like they may have to go out of network to source it.
Still waiting on the dealer to set up a start date. Figured it would be a good idea to have a hydraulic top link on hand when they do. Probably putting in an order for link & hoses at Agristoreusa.com tomorrow. Looks like 2-3 day delivery to NC.
   / Looking at a hydraulic offset flail for the 3038e -It's Home! #15
Just be very careful when you offset or go vertical with that new flail. It could, very likely, bring your tractor to the tipping limit.
The only thing I had to do was add more air to the rear tires. I only run enough air to keep the tread in full contact with the ground. That's about 8-10psi. When I lifted the mower for the first time, it was already extended (assembly process). The right tire went nearly flat. I carried it back to the barn that way because I didn't have the correct hydraulic couplers. I didn't feel anything squirrely about it. I just took it slow so not to pop the tire off the rim.
Everything is finally in at the JD dealer (after the flail being lost in transit for a bit). Took the 3038e in this afternoon along with the hydraulic top link kit I picked up.
Pics after I get it back.
   / Looking at a hydraulic offset flail for the 3038e -It's Home! #17
Looking forward to see this rig and learning the final costs.
   / Looking at a hydraulic offset flail for the 3038e -It's Home! #18
Word of caution...feather the hydraulic shift slowly.
My tractor is much heavier and the flail still wants to wag the dog.
Listen to Leon. He is the flail king of TBN.
Yep, that's why I went with the JD mechanical scv kit rather than a solenoid based solution. Still may end up adding restrictors on the flail cylinders.
   / Looking at a hydraulic offset flail for the 3038e -It's Home! #20
A 3 series tractor pulling an offset flail? I hope you JD dealer ordered a truck load of wheel and front end weights for you. I've been running ditchbank cutters for 45 years. I wouldn't think about putting an offset like that behind anything less than 8000 pounds. The most dangerous thing is hooking something with the deck and rolling the tractor. It can happen in a flash. I know. Just be careful. I know you are excited with your new $12k addition but be very careful. And seriously, get your self some weights.
2016 BOBCAT T630 TRACKED SKIDSTEER (A58216)
2016 BOBCAT T630...
(16) Aluminum Scafolding (A59225)
(16) Aluminum...
2019 Chevrolet Tahoe SUV (A56859)
2019 Chevrolet...
Mini Skid-Steer Grapple Bucket (New/Unused) (A59225)
Mini Skid-Steer...
2016 Chevy Tahoe (A56859)
2016 Chevy Tahoe...
2006 Volkswagen Jetta Sedan (A55758)
2006 Volkswagen...
