casper6871
- Joined
- Jan 31, 2010
- Messages
- 18
guess i hi jacked the thread... sorry
Depends if you have an early or late SN. On the late, dipstick is below your legs as sitting on the unit. If it's an early, You'll have a sight glass on the rear of the tractor, near the pto. The fill plug is on the back to the right of the top link bracket. If it has a loader on it, you will have to remove the return hose, from the loader,and remove the 90 degree elbow. Remember, this is for hydraulic, transmission, and diff.. Use a trans- hydro fluid designed for both. Also remember to check the outboard final drives, as they have seperate oils from hyd. tran oil. Final drive fluid is SAE 80w90. Factory put white paint marks on the plugs. About half way up on the final drives.
