Long 445
   / Long 445 #1
pycoed
West Wales UK
Zetor 7045; Yanmar YM1820;Wheelhorses C121, C101, A8;Cushman Turf truckster
Should the TPH arms power down as well as up on the Long 445? Mine lift fine, but won't come down without some weight on them. This is my first real tractor so I don't know if this is normal. If it ain't, where should I look to clean/adjust/repair?
   / Long 445 #2
I could be wrong but I don't think any of them have power down on the TPH.
   / Long 445 #3
You should have a valve that controls the bleed rate as you push your control lever to lower the arms. I don't know your model, but it is usually right under the seat between your legs. If it is set fairly closed (like you would for a heavy implement so it doesn't drop like a rock) the arms alone will fall VERY slowly, if at all -- but that isn't anything "wrong". If you open that valve up, even the arm weight should be enough to drop the arms fairly quickly -- just remember to adjust it back down when you put the XXX pound whatever on the 3PH or XXX will become the proverbial rock when you go to lower it.
   / Long 445
Thanks Vistan - I do have a sensitivity control on the TPH. I'll give it a whirl & see what happens. What you describe makes sense to me
Cheers
JohnL
2005 John Deere 7420 (A60462)
2005 John Deere...
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
2018 Ford Escape AWD SUV (A59231)
2018 Ford Escape...
Kubota ZG222 (A60462)
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
2001 BOBCAT 773 SKID STEER (A60429)
2001 BOBCAT 773...
