Long 2360 sitting 2 yrs
   / Long 2360 sitting 2 yrs #1
Jmarkv
Middleburg
Long 2360
I just took over my folks 40 acres and found out that they haven't cranked their long tractor in over 2 yrs. can anyone offer any advice before I get started on it?
Thanks, Mark
   / Long 2360 sitting 2 yrs #2
Out doors or under a roof?
Check if you can turn the engine by hand a for a few turns.
Check oil and water, a fresh batteries and give it a try, 2 years isn't so long.
Can be an idea to have a fire extinguisher ready if things happen.
   / Long 2360 sitting 2 yrs #3
Welcome to TBN!
There is actually a fairly long thread that just started on whether you should periodically start machines that sit for extended periods of time....let's just say it's a contentious issue. Folks posting in that thread described situations where they had machines sit for even ten years, and all they did was put a fresh batter in it, prime the fuel system (I think) and start it with no problems.
I bought a very old dozer from my neighbor, and it sat for two years....we put a battery in it, and it started right up.
Some folks will likely suggest any number of things like pulling the injectors or glow plugs and squirting some penetrating oil into the cylinders and let it sit for a couple of days, then letting it crank a bit with no compression to get the oil moving. You could actually change the oil and filter before doing that so you're moving good oil.
Some folks will leave the injectors/glow plugs in place, but spray WD-40 into the intake to try adding a little lubrication while it's first cranking (probably need a helper).
Other might suggest pulling the compression release or disconnecting the injector pump (many have an electric shutoff tied to an oil pressure sensor) then cranking the engine to get oil pressure up before actually starting it without trying to get anything into the cylinders first.
I'm not familiar with Long tractors, but I think I'd either use the compression release or figure out how to disable the injector pump (electrical wire, or loosen the fuel input line) so the engine can't start, then crank it for a bit (maybe 15 seconds), then try to actually start it. I'd look at the oil first, and if it looks milky, or like tar, I'd probably change the oil and filter first, just to be safe.
Let us know how it works out!
Thanks for the reply, it's inside a closed barn in north central Florida. I checked the oil and it looks really clean, however I think my dad over filled it when he changed it last, would that be a problem for this 3 cylinder engine? Also, I noticed the power steering dip stick showed nothing on it should i change that fluid or just add to it. The trans fluid looks good and at the right level, the antifreeze is nice and green. All 4 tires look a little low on air, especially the right front it's getting closed to sitting on the rim.
I appreciate any advice, Mark
   / Long 2360 sitting 2 yrs #5
It can be the power steering fluid leaked through the pump and ended in the engine and causing the overfill.
That can't be good if that's the case. How can I tell for sure and will the power steering fluid hurt the engine?
If that is the case should I change the engine oil and also change the power steering pump or at least the seal that must be allowing the oil to leak through to the engine.
   / Long 2360 sitting 2 yrs #8
Do you know what type of oil there is on the power steering?
Yes the manual says Exxon torque fluid 56 was in the power steering and chevron 15w 40 is in the engine.
I found bottles of both in the garage where the tractor is kept so I can assume that is what is in it as we'll.
12" x 16.5" Kubota RTV-X1140 Tires (A52377)
12" x 16.5" Kubota...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2011 Homesteader Box Trailer, 6'x10' (A52384)
2011 Homesteader...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53472)
2016 RAM 5500...
