Lombardini small 4wd tractor spinning wheel
   / Lombardini small 4wd tractor spinning wheel
Most of the mentioned parts i dont know what us it but i will open the top cover and i will share photos for all parts soon here to get any advice .thx for your support for now 😊
Hi Mr.ptsg
Im near to the tractor .it eill be appreciated if you give me your face book address or messenger its easy to share phots and video .
by the way we opended the top cover we found no oil there but it filled with greas and i think since long time it happen .
All gears teeths from where we can see inside seems ok.no broken teeths
But in your photo you shared there 2 wholes with minuse head to fix to spring with head in top to catch the 2 rods when we change the gear postion fron 1 to 2,3 etc
In our tractor when you remove the top cover these 2 springs comes out and there is no covers for it
And i want to ask when we fix the rods what the correct postions for these rods wholes to be sure it in nutrsl not in the first or seconed or fourth speed .
thanks in advance
I will share some of photos if it will help
   / Lombardini small 4wd tractor spinning wheel #13
Lombardini makes engines, not tractors. What tractor do you have that is powered by a Lombardini engine? Pasquali? Goldoni? Agria? Ferrari? Valpadana?
Also, what is a "blough"?
Only 'Blough' I know of is the Rodger Blough, which is a now dismantled Great Lakes ore carrier....:unsure: Talk about 'fat finger/ spelling, his post is rife with it...
   / Lombardini small 4wd tractor spinning wheel #14
It is hard to tell from the picture, but is the pinion gear completely worn out? See circled gear.
   / Lombardini small 4wd tractor spinning wheel #15
If you disengage/take it out of 4Wd does the tractor move at all? Does it try to pull the plow?
By the video it looks like only the front wheels are turning. When you plow the front end is lighter/and or may be the only wheels pulling.
   / Lombardini small 4wd tractor spinning wheel #16
He not from the usa, give him a break on his english. May be trying to use a *** to English translation tool.
   / Lombardini small 4wd tractor spinning wheel #17
English and USA need to be posted in upper case btw. I realize the OP isn't. Just poking fun and nothing more. I looked at his 'bio' and it don't list his native country...
I will say his pictures reveal a rusted mess with no lubricant present.
   / Lombardini small 4wd tractor spinning wheel #18
Hi Mr.ptsg
thanks in advance
Hello alaaahmad,
Thank you for the pictures. As far as those springs, don't worry, the top cover is what holds them in place.
The pinion shaft is completely stripped as TGMT pointed out. Not teeth left. Most likely due to lack of the proper oil. Should have 80W90 oil.
I suggest that you find a mechanic because right now, everything inside that gearbox needs to come out as the pinion shaft is the last one to be removed.
This is a picture from the gears from the front gearbox but it has the same ring and pinion setup. Inside the blue circle is the pinion gear and how it should look with the teeth in good condition.
Sorry for the bad english as i im not a native engilsh speaker, im from jordan if you know and we speak arbic, im not using any tralslation app put iam writeing very fast and from what i saied i think my quastion can be understood by the others so if you want to share a comment about my written words you can be an engilsh teacher and i will register with you🫡
By they way that word blough i took it from the internet when i ask about it meaning in english becuse i dont know it exact meaning .
so sorry for my weak Languge word.
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A53472)
2006 Magnolia Dry...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
