logging winch question[Farmi]
   / logging winch question[Farmi] #11
Both above comments are accurate and good advice in my experience. Wrap a choker around the base of a tree attach to a slider and use it as a snatch block. I would advise no more than about 60 degrees of angle as you risk putting a permanent kink or "curl" in the cable with anything more severe than that.
If you are lifting your tractor off a real wheel, you might want to cut that angle down! all that weight is on one lift arm, pushing up (ie compression). You can do a LOT of damage that way.
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A59575)
2005 INTERNATIONAL...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
Forklift (A59228)
Forklift (A59228)
Rhino DB150 (A57148)
2008 MAXX-D FUEL TRAILER (A58214)
2008 MAXX-D FUEL...
