Logging tongs
   / Logging tongs #12
Those are definitely "skidding" tongs, not lifting tongs. At least, that is the design. Obviously, in a pinch, they will lift.
The other thing is that tongs are made to go around the circumference of the log rather than as they are used in the photos. But...whatever works is the farmer's creed.
Here is a set of spring loaded skidding tongs:
Timber Tuff Spring-Loaded Log Tongs — 22in. Jaw Opening, Model# TMW-22SSS | Log Skidding| Northern Tool + Equipment
Here are lifting tongs (note the price!!!!!!!!!!!!):
LITTLE MULE Lifting Tongs, Timber Type, 5000 Lb Max - G1575944 at Zoro
Here are skidding tongs much like yours:
Roughneck High Carbon Steel Swivel Skidding Tongs — 17 1/2in. Jaw Opening | Log Skidding| Northern Tool + Equipment
Perhaps you can see the difference in design.
   / Logging tongs #13
Still can't tell the difference between skidding and lifting tongs. They both seem to have tongs angle up to dig in. Other than the swivel, what differences am I missing?
   / Logging tongs #14
Timber Tuff Spring-Loaded Log Tongs 22in. Jaw Opening, Model# TMW-22SSS | Log Skidding| Northern Tool + Equipment
I have a set of these or very similar tongs. They work okay but not great. The sharp points on the tongs are replaceable but they are only held in place by a half moon key. Sometimes you need to set the points into the log and you need to hit them with a hammer. All this does is pops off the half moon key and the points will fall out, then you are done until you find the point and the key. My advise is to buy a better set without the replaceable tips and half moon keys.
   / Logging tongs #15
The lifting tongs have longer and thicker points at a greater angle. The points will remain an angle when the tongs are spread. That way the lifted log stays attached to the tongs. They are also constructed out of heavier material.
The skidding tongs have shorter, less angled points. When spread, the points are parallel to the ground, or the log's surface, rather than pointed up. It can be seen in the photo of the round being lifted.
The skidding tongs are also designed to slip off if, say, the log being skidded hangs up on a stump. The tongs and the tractor are spared damage.
   / Logging tongs
Would any one try to heat up tips and bend em ??i use chokers for skidding
   / Logging tongs #18
Do what DOZERNUT said and hit one side with a four pounder a couple of times. You don't have to hit both sides most of the time. Don't heat them. The size you have should work fine for firewood length.
Pan
17201 (A55852)
17201 (A55852)
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
John Deere 6110M (A53317)
John Deere 6110M...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
2006 Intellistrobe Automatic Flagger Assistance Device S/A Towabale Trailer (A55973)
2006 Intellistrobe...
Toro z turn (A56859)
