Chains Logging chains
/ Logging chains #1
Harv
Elite Member
California - S.F. East Bay & Sierra foothills
Kubota L2500DT Standard Transmission
Well, still no word on when my tractor will arrive, so I'm easing my anxieties by shopping around for some of the basic paraphernalia that I thinkevery tractor owner should have.
One of my first tasks will involve moving several 10-ft sections of steel culvert pipe around. Diameters will be in the 12 to 24 inch range. There are also a couple of dead trees in the way that I would like to move elsewhere. Now, whether I drag with the towbar or lift with the loader, it seems like chains are the way to go.
I just spent a couple of hours driving around looking for chain only to discover yet another world I know nothing about. I had no idea there were so many sizes, finishes and prices!!! Then there's the slip hooks, grab hooks and a bunch of other doodads I don't recognize. (I gotta admit I love this stuff -- at Orchard Supply a sales guy came over 'cuz he thought he heard Tim Allen, oh, oh, oh /w3tcompact/icons/smile.gif).
So I need some guidelines here. Is 3/8" big enough for my needs? It's rated at something like 2560 lbs, comes in plate or galvanized, and then there's that "system 7" stuff. Prices range from $2.50/ft to $6.99/ft.
I get the feeling I should be shopping at a farm supply or some kind of big-rig truck shop, but I haven't found either around here.
Anyway, I bet you all have piles of chains for using with your tractors. What are you using? Where'd you get it? How much did you pay?
/ Logging chains #2
Harv, I put a 3/8" grab hook on top of the front end loader bucket on each end and use a variety of chain lengths. The heaviest chains (and most used) I have are the 3/8", although I have several small light chains for the occasional light job. I use grab hooks for everything except for one slip hook on a cable for a choker.
Bird
/ Logging chains
Rich -
Wow! /w3tcompact/icons/shocked.gif That's some chain! What kind is it? The highest rated 5/16 chain I can find (system 7) is only rated at 4700 lbs. Is there an actual type of chain called "logging chain? If so, where do you get it?
Thanks for the tip about labonville.com. I ordered their free catalog.
/ Logging chains #5
Storing chains on the tractor can be a problem. My solution is to get an ammo box about 4x12x8" and attach it to the side of the loader arm with 3 or 4 long stainless worm-gear clamps. The lock down clamp on the top of the ammo box is sturdy enough to keep the chain inside when the loader arm raises up to its maximun of 45 degrees or so; the lid has a good gasket on it to keep things dry. Drill a weep hole front and back in the bottom of the box so water the does get in runs out. Make pairs of slits on the side of the ammo box that go up against the loader arm and thread the clamps through there. I've never had it get in the way. Before chains were coming unhooked, falling off,getting jamed at the edges of the platform etc
RCH
/ Logging chains #6
Rch, sounds like a great idea!! I going to give it a try. Mite you or any one have any ideas on how to or where to carry a chain saw?? Not in the bucket!! That cost to much/w3tcompact/icons/frown.gif Had a older tractor and just put a box on the hood but I don't want to do that with the new one.
Rich
/ Logging chains #7
8/25
I know Harv isn't local to me (nice picture on your bio page), but if anyone wants 3/8 G7 chain for $1.75/ft (US made) in the Richmond, VA area, Chesterfield Trading has it. I bought 150 ft the other day, now to cut it into useable lengths /w3tcompact/icons/crazy.gif.
That can be a challenge I am told, esp with the G8 and grade 100 chains. My chain was cut by a guy stepping on a 3+ft bolt cutter on the concrete floor with much grunting. And it was G7.
Bird, who was it that recommended slip hooks at either end of the loader bucket with a grab hook in the middle, thought it was you but yours is different?
I bought the weldable slip hooks (expensive, made in Sweden) for the ends of my bucket, but some folks have done it with regular materials bolted on, etc.
Harv, there is an earlier thread where guys like Bird, Mark Chalkley and others talked in detail about using chains creatively and safely. I learned a lot and recommend it (check the archives). You can be severely injured by these seemingly innocuous things in combination with the power of a tractor.
HTH,
Jim
/ Logging chains
Jim -
That's a very good price on 3/8 chain!
The best price I've found locally is $2.50/ft. Tell you what -- shove as much of that Chesterfield Trading chain as you can into one of those Express Mail envelopes and you can ship it to me for only $3.25!
You know, I thought I had searched the archives for chain discussions, but apparently I didn't set the search to go back far enough. I just tried again and found tons of posts on this very subject. Sorry to bother everybody with a question that's already been answered to death. /w3tcompact/icons/blush.gif
After reading the discussions about various ways of attaching chain hooks to the top of the loader bucket, however, I now have a new question -- I like the idea of the quick-attach bucket forks such as offered by Gearmore:
These forks require that you attach their special hooks to the top of your bucket so you can just "scoop up" the forks and away you go. The question is, are those hooks also sufficient for chain use? Anybody seen them up close?
/ Logging chains #9
Harv,
Those types of forks are pretty common and I think both Del and Bird have sets for their tractors. You do need to remember that on a small tractor you setting the wieght even farther in front of the tractor and need some serious counter wieght on the rear. If you plan a lot of heavy lifting a quick release for the loader bucket and a set of forks that replace the bucket is the better set up.
I think your signature with tractor is great!
/ Logging chains #10
jgh, like you, I remember someone posting a message about using the slip hooks on their bucket, but I don't remember who it was. I've always used the grab hooks.
Bird
/ Logging chains #11
Harv and MarkV, that's very interesting. I don't have quick attach forks, but Harv's picture sure looks a great deal like what I have. My brother traded for a used set of 4' forks off a regular forklift and described for me a set on front of a tractor that he had seen, so we did did a little cutting and welding; welded brackets on either end of the bucket, but I have to get off the tractor and slide that pipe at the top through those brackets to put mine on. And as MarkV said, you do want to be careful about the extra leverage to avoid damage by having those forks so far out in front. The best thing about mine is the fact that a few welding rods is all it cost me./w3tcompact/icons/smile.gif
Bird
/ Logging chains #12
Harv,
If you check out the thread titled "L4310 enhancements" on this forum you'll see some pictures of my 4-in-1 bucket and pallet fork hooks, among other things. There's a post dated 7/26/00 at 3:08 PM that offers the best picture of what you're talking about.
And, to answer your question, they make excellent chain hooks.
Mark
/ Logging chains
Mark -
Welcome back! Sorry to hear about your illness, but glad you're feeling better. You dropped out of sight just about the time I joined the group, and I was beginning to take it personally./w3tcompact/icons/crazy.gif
Thanks for sending me to such a good thread. I downloaded all of your picts for my own scrapbook. You have a terrific rig and I love the way you've done your own improvements. I'm dying to do the same, but first I need a tractor. /w3tcompact/icons/blush.gif
Anyway, your pictures and comments cleared up a lot of questions I had about bucket forks, but now I'm considering a loader rake, as per my recent post.
Stay in the shade. /w3tcompact/icons/cool.gif
2020 Ram 1500 Pickup Truck (A64194)
2020 Ram 1500...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
1/2" Quick Attach Blank Plate (A66408)
1/2" Quick Attach...
1998 MAC 39' Frameless Dump Trailer (A66285)
1998 MAC 39'...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
NEW ATS-SP100 100 Ton Capacity Shop Press  (A62679)
NEW ATS-SP100 100...
