Hermio
- Joined
- Jul 28, 2014
- Messages
- 363
- Location
- Clarksville, OH
- Tractor
- Mahindra 5035 HST w/FEL and 4-way bucket; Ford 4110
As I mentioned a few posts ago, I do the hard pulling with the chain attached to a drawbar at the bottom of the quick hitch. This transfers the pulling load almost entirely to the bottom links. Only when I have the log on my logging roads, which are bush-hogged, do I transfer the load to the top of the quick hitch so I can get the tractor close to the log and lift the log off the ground. This is pretty much the same way that folks with winches do it: they use the lower pulley position for dragging to the winch, then the upper position to lift the log. Some then drop the choker chain into slots on the winch. This is a good idea, unless you know you will cross a very muddy area or go up a hill, in which case you may need to let the winch line play out as you cross the bad spot with the tractor, then winch it in again when you are on better ground.
