Log tongs
/ Log tongs #1
bobodu
Platinum Member
Whitley County,In.EIEIO
Farmnought.Gravely Model L,Gravely Model LI,1941 Clinton two wheeler
Made these today...
Just some 3/4" X 3/8" flat stock heated up in the wood stove and bent into a hook. Then,I backed that with another piece of flat stock to make a "T" cross section. Some 1/2" pieces of stainless round rod make up the teeth.
/ Log tongs #2
Heating in a wood stove is a practical idea. Lots cheaper than oxy-acetylene!
That's using your head - and stove. Blacksmithery is a handy knowledge.
/ Log tongs #3
very nice, we've got a few sets of these, that we got cheap off the forestry commision or another big company because they were getting rid of old equipment
/ Log tongs #4
I recently made a cant hook for no cost. Catalog prices are $70 or better. If you can make it or find it nearly free thats best. I used to have a small sawmill and used skidding tongs to drag up all the logs to the cold deck.
/ Log tongs
Built my first forge when I was about 14 at the tail end of the steam locomotive era. Back then,it was real handy to walk down the tracks a half mile and pick up all the free coke I could carry. Now days,it's just a pain in the butt to even find coal around here. It can be had but it's not really worth my trouble. Thought about a gas forge....but it lacks the "magic" of a good fire. I use my O/A torch on some small stuff and my weed burner on the larger bits. But as anyone who heats a shop with wood knows,you seem to spend a lot of time poking the fire whether it needs it or not!! Might as well heat some steel...
Here's a shot of my stove..the firebox is a 60 gallon compressor tank and I have a furnace blower behind the heat exchanger. I have since insulated the walls and covered them with tin from a feeder bunk roof.
2008 Generac SD100 T3 125kVA Standby Diesel Generator (A66734)
2008 Generac SD100...
225/70R16 Tires - Set of 4 (A68134)
225/70R16 Tires -...
CLUB CAR  CARRYALL 6 (A67714)
CLUB CAR CARRYALL...
HOSE REELS (A68842)
HOSE REELS (A68842)
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
YALE FORKLIFT (A63291)
