Log Splitter
/ Log Splitter #21
Just wanted to throw in these pics. I sure you can make some improvements on this one. Might give you some ideas though.
/ Log Splitter #22
I think your log splitter is the neatest i've seen. In your other posts about your log splitter do you give the deminsions for the i-beam (width, length, hieght, thickness of the material sort of thing).
/ Log Splitter #23
Stray,
I don't know much about hydraulics, but I was wondering (for the price, $69.99) could this 'Harborfreight Log Splitter' be adapted to use with the PT:
http://www.harborfreightusa.com/usa/itemdisplay/displayItem.do?itemid=39981
"CENTRAL HYDRAULICS"
TWO SPEED, 10 TON HYDRAULIC LOG SPLITTER
'Quick log splitting at an affordable price. Manually operated, two speed pump builds up to 10 tons of log-splitting pressure fast. Pump is operated by two 29-1/2'' steel handles. Includes pressure release valve.
Heavy duty spring return
Accepts up to 18-1/2'' long logs
Accepts up to 6-1/2'' diameter logs'
I have a small wood burning stove and some of the wood I purchase is all ready split, but some of it I would like to spit even further.
Thanks in advance for your time and info, and great job on your splitter.
Abe.
/ Log Splitter #24
Yes, with a different cylinder of that size with pipe connections. With one that size you could use the quick attach Hyd system (the small connections not the PTO) and obtain a satisfactory speed. You may or may not like the size limit of the wood it will split. But it would be cheep and a good project to introduce you the concept.
Quick connect hook ups deliver about 3 gal per minute.
PTO connect hook ups deliver about 8 gal per minute.
/ Log Splitter #25
ldabe said:
Stray,
Abe.
I think you would be disappointed with that small unit. Stray has one built for his machine. I have one of the Northern Tools PT units that is driven off the rear hyd circuit of my Kubota. The log splitter from Northern Tools, comes almost ready to install. You would have to put a mounting bracket on it, and plug in the hydraulics. This unit will handle 24 in logs. If you have the capabilities, you could round up all the parts, and save a little money. If you can find a gas driven log splitter, that has a blown the engine, you could probably get it cheap.
/ Log Splitter #27
Man! You guys are good!
It never ceases to amaze me on the knowledge of this forum. And quick too!!
Thanks fellas, I think you covered all the bases and gave me plenty to think about (now all I need is some time and money).
These guys are good, real good...[walks off in amazement, shaking head with huge smile on face, muttering under his breath with wife staring over top of glasses and thoughts of guys in white coats showing up at front door].
KENT HYDRAULIC HAMMER ATTACHMENT (A60736)
KENT HYDRAULIC...
Volvo EC220EL (A60462)
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
2021 CATERPILLAR 259D3 SKID STEER (A62129)
2021 CATERPILLAR...
