Log splitter???
   / Log splitter??? #1
Hookblock
WI
JD 4310
Is there any way to tell if I have a two speed pump on my log splitter. No name on the pump, it's about 30 yrs old, newer 9 hp motor, not home made. I am using it more and it is under powered and a slow cycle time. So I am wondering if a new pump would help? Thanks
   / Log splitter??? #2
with twospeed pumps there are two pumps in one. With a single there are usually three parts, two ends and the pump mechanizm in the middle with the in and out side ports. With a two speed there will be 5 parts as there will be a partition between the other smaller pump. If it is pulling the engine down, it is most likely a single stage and if it is too slow for you, it takes hp to get speed and push power.
   / Log splitter??? #3
Sounds like a single stage pump. With 9hp id replace it with a 16gpm 2 stage pump.
larry
   / Log splitter???
Thanks for the info, I'll look at the plates on the pump tomorrow, and look into a 16 gpm pump
2025 KG45 UNUSED U-Type Screw Pin Shackle Set (A50860)
2025 KG45 UNUSED...
2015 International DuraStar 4300 26ft. Box Truck (A48081)
2015 International...
2011 TROXELL 140BBL TRIAXLE VACUUM TRAILER (A50854)
2011 TROXELL...
2021 Bell B30E Off Road Dump Truck (A50860)
2021 Bell B30E Off...
1991 GMC Sonoma Pickup Truck (A48081)
1991 GMC Sonoma...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
