Log splitter???
/ Log splitter??? #1
Hookblock
WI
JD 4310
Is there any way to tell if I have a two speed pump on my log splitter. No name on the pump, it's about 30 yrs old, newer 9 hp motor, not home made. I am using it more and it is under powered and a slow cycle time. So I am wondering if a new pump would help? Thanks
/ Log splitter??? #2
with twospeed pumps there are two pumps in one. With a single there are usually three parts, two ends and the pump mechanizm in the middle with the in and out side ports. With a two speed there will be 5 parts as there will be a partition between the other smaller pump. If it is pulling the engine down, it is most likely a single stage and if it is too slow for you, it takes hp to get speed and push power.
/ Log splitter??? #3
Sounds like a single stage pump. With 9hp id replace it with a 16gpm 2 stage pump.
larry
/ Log splitter???
Thanks for the info, I'll look at the plates on the pump tomorrow, and look into a 16 gpm pump
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
2022 EZ-GO ELITE...
Pallet Racking (A65640)
Pallet Racking...
6 Ratchet Straps (A65579)
6 Ratchet Straps...
New/Unused ATS Electric Jack (A65583)
New/Unused ATS...
2017 Ford E-Series FedEx Delivery Truck, 5.4L V8, Step Van Conversion (A63689)
2017 Ford E-Series...
