Log Splitter valve used as remote
/ Log Splitter valve used as remote #1
hahnderosa
B7500
First of all, thanks to all who have posted information about hydraulics. I searched and used the info to determine how to operate a three pt. hitch mounted log splitter that was purchased fro Northern Tools. $400.
I did not want to have to remember to connect supply and return lines (from my FEL "power beyond" and back to the tractor) when the splitter is not in use, or have connections come apart accidently. That would damage the tractors hyd pmp. Of coarse, I first checked that the valve was an "open center" design. So I removed the valve from the splitter and mounted it on the tractor. Now I have a remote that can be used for other implemnts, although I don't know what else I would use. I'll try to post some pics.
Thanks, Scott
/ Log Splitter valve used as remote #2
Excellent, But someone stole your ROPS:eek:
Welcome to TBN:D
/ Log Splitter valve used as remote #3
Scott,
Wow this is a really good idea
Could you post how you tied the valve into your power beyond (after the FEL).
I have the Kubota L3400 with the FEL tied into the the front hydraulic block.
The valve that comes with Northern Equip splitter is the Prince 3000, it doesn't appear to have power beyond connections to the rear hydraulics.
Thanks,
greg
/ Log Splitter valve used as remote #4
Excellent idea Scott- thanks for sharing that and please do post more details as I figure I will buy a splitter for my B7800 next year
/ Log Splitter valve used as remote #5
That IS a very good idea! Would love to see pics on how you hooked this up to the loader block. Thanks!
/ Log Splitter valve used as remote #6
Awesome idea, I just bought a 30 ton unit from Harbor frieght tools, maybe I can do the same to my b21.
:confused:
/ Log Splitter valve used as remote #7
Scott:
Neat job.
Your valve tank port appears to connect to the inlet port of the three point hitch, which means that the hydraulic fluid flowing through the valve powers the TPH as well. If so, when the TPH lifts an implement, the fluid pressure needed to move the implement will also be present in the tank/outlet section of the log splitter valve. Many valves have much lower pressure ratings on the tank section than on the inlet section, and are designed to be used as the last valve in a series where there are no downstream devices (cylinder, motor, etc.) to put sigificant back pressue on the tank section of the valve.
If these pressure limits are exceeded the seals at each end of the spool which keep fluid from leaking out between the valve block and the spool can be damaged, causing the valve to leak. The valve manufacturer should be able to tell you the pressure rating for the tank section of the valve.
I realize that you are lifting the log splitter with the valve in place, but the log splitter is probably light enough that the pressure required to lift it does not exceed the valve limits. However, a heavier implement, such as a rotary mower or lift platform, could require much higher pressure.
/ Log Splitter valve used as remote #8
New Kid Here,
Do I have enough muscle to operte a log Splitter with my BX24?
Dealer wasn't real supportive but I think that is because he didn't supply any:confused:
/ Log Splitter valve used as remote #9
I'm with farmerford.. many valves do not like pressure on the outplet port.. that's what powerbeyond is for..
soundguy
/ Log Splitter valve used as remote #11
Tango Hotel said:
New Kid Here,
Yes, you have enough muscle. What you may not have is enough flow (speed).
I have one of Northern's log splitters on a BX1500. Northern recommends 11 GPM. The BX1500 suppplies at most 4 (3.something) GPM via the loader ports. I beleive the BX24 is the same, and if it's not, it'll be a bit better.
That said, I'm quite happy. I move right along, and do sometimes have to wait for the splitter, but it's not too bad. I'm also not 22 years old anymore.
If I were splitting commercially, or if I had a second person helping me, it'd be too slow.
I only split a few cords per season.
While I plan to improve the system sometime, I plumbed the splitter directly to the loader ports. It does mean long hoses, but it was easy. I leave the bucket up a few inches while splitting, so I can reposition the tractor without shutting it down and switching hoses.
8x8 Meyer X1206 Farm Wagon (A65579)
8x8 Meyer X1206...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
3ft Metal Jeep Tailgate (A65583)
3ft Metal Jeep...
East Texas Gooseneck Trailer (A65563)
East Texas...
2022 EZ-GO ELITE...
