Log Splitter Question...
   / Log Splitter Question... #11
If you're standing in front of it and not off to the side I'm not seeing it to be a big problem with throwing pieces at you. I used to have a horizontal/vertical splitter until it got stolen. Sitting on a stool with the splitter in the vertical position was the best way to use it. I currently have a horizontal only splitter with the wedge on the beam with a 4 way. It's way more comfortable and a lot faster. But unless you plan on selling wood on the side pretty much any design is going to work. I burnt about 7 cord a year and split that much more for my grandpa. Over the span of several weekends that's an easily doable workload on my old horizontal/vertical splitter.
   / Log Splitter Question... #12
Funny You mention Your first splitter being stolen , as My first was more or less stolen also . Older brother who lives in Washington " Borrowed " it . Rather than return it , said he would " Buy " it . Set a price which He agreed to . Funny thing was though that I only got half the amount and that was over 20 years ago . Think I used that splitter for over 6 months lifting big rounds up onto a table I built next to it before I realized I could pull a pin and split vertical , ( and that was because I just happen to drive by were I bought it from and they had 2 out front , one in horizontal position and other in vertical :confused3: ) .
Unless one has the material laying around already , for the small price's they are selling for , I don't see making one being practical . Butthat can be said for a lot of implements . I have a local steel dealer who sells new , new old stock and used , thus many times I can go through their yard and rather than pay new steel prices , can pick up what is needed out of NOS racks or even recycled racks for $$$$ less .
Fred H.
   / Log Splitter Question... #13
Rounding up pieces to build a 3 point log splitter to use on my Kubota and looking through the builds here I've noticed that some use a splitter wedge on the ram and some are stationary, any advantage or disadvantage of one over the other? Thanks!
Since you are "Rounding up pieces to build a 3 point log splitter" I'll address that part of your post. I too once did that and my splitting device was a piece of thick steel as I saw on commercial units. I had low power due to a small diameter piston and had slow movement due to using a Ford 2000 4 cyl as the hydraulics source.
After numerous attempts what I found to work best was a modified wedge where you take what is sold commercially and about an inch behind the blade tip, weld deflectors to it. I'll see if I can find my pictures. If I do, recall that I started with the center wedge made of a single slab of steel.
These pictures are of the solution. In them I have upgraded the piston to 4x24 and changed out the water pipe fittings for regular hydraulic units. The rest of the cutter I had from earlier running with the tractor. The power unit is a 15 hp Scotts lawn tractor I had sitting around. Pump, splitter control, tank, filter, and Lovejoy fittings and all came from N. Tool. Pump is 16 gpm 2 stage, 8 hp requirement (engine is 15 hp), very reasonably priced. My cycle time is in single digit seconds, unloaded out and back. I built it near the ground so that I don't have to lift any heavy logs. I have a tractor with a FEL and bucket into which I toss the splits which go to my wood pile located in a shed...just dump them in....minimum manual labor as I can get for the money and time spent in the task.
As to which moved I'd say it may have been designer's choice to fit their intended package. It does seem that moving the wedge would be more effective due to the shape of the faces of the log to be split and friction of the driving mechanism. May be that moving the wedge worked better on irregular cuts of logs.
   / Log Splitter Question... #14
I like the wedge on the ram. I'm often splitting large pieces and even a 4 way splitter isn't going to make them small enough so having the ram push them off the end of the splitter forcing me to pick up the pieces that need to be split again is just more work. For the really large stuff I can stand my splitter up. I usually have a large log on end or some other form of table close by to put the split pieces that are too large and need to be split again. With the splitter parked as close as I can to the pile of rounds I'll split a tanks worth and just toss the splits a few feet away. Often my pile will reach 6 feet or so in height (something you can't do with it being pushed off the end without a conveyor belt to lift it up) so the area the pile of splits is occupying doesn't get too massive.
If you haven't bought the pump yet I would look at buying a two stage pump as speed could be an issue. With a 2 stage pump you could pretty much set your tractor close to idle and still have the power needed without going deathly slow.
   / Log Splitter Question... #15
We've got a horizontal splitter with the wedge on the beam and the pusher on the ram.
I'll repeat other's comments about splitting large wood with it...
You split a 36" piece of wood and it pushes the whole thing through the wedge and drops in half(on lucky days).
Then you have two large halves that you have to pick up and slide back to the front of the wedge and repeat. You're basically moving that piece of wood many times back to in front of the wedge.
If the wedge were on the ram, the halves would fall before the end of the beam. You'd still have to pick them up and put them back on the beam, but you wouldn't have to move that extra 2' each time.
If you had a table to catch the splits on a horizontal unit, that would be the real work saver in my opinion. You could just slide the pieces around and never have to lift the splits.
   / Log Splitter Question... #16
I can sure see production benefits of wedge on beam...
That said... for what I do not having to elevate or lift large rounds makes it possible for me to split in vertical position... and so much easier on the back.
   / Log Splitter Question... #17
I have a horizontal/vertical splitter with wedge on ram.
I like the horizontal/vertical feature as it makes possible to split large chunks that would otherwise be impossible.
With wedge on ram, you'll need to weld "stops" on the beam that stand up on each side of the wedge at it's retracted location. These are so when the wood gets stuck on the wedge and you retract the wedge, the stuck wood hits these and is knocked off the wedge instead of hitting the cylinder.
The problem with these is safety. Everybody is usually careful and watches their fingers on the split stroke when thing are popping and splitting, etc..; but when the wood gets stuck on the wedge during the retraction stroke, it's natural to grab the wood and try to pull it off not realizing that your fingers are now in between the (cylinder) end of the log and these stops. And if you keep them there they'll be crushed.
Many people just aren't looking for danger on THAT END of the log when you're not even splitting it anymore and retracting.
   / Log Splitter Question... #18
I managed just fine without the stops. For the rare basis that I got a piece stuck I would hold a piece of firewood between the stuck piece and the cylinder. Then I'd retract the cylinder. Before I discovered that I usually drove them off with a sledge hammer.
   / Log Splitter Question... #19
You're right, it's probably safer without them than with. Mine came with them.
One can also just put another small piece of wood on beam so that the wedge can now drive ALL the way through the stuck log.
   / Log Splitter Question... #20
I built a splitter in the 70's that initially ran off the tractor pto. I put an engine on it so I could use the tractor to move logs and push the wood away. You can find it on youtube. Plumbstriaight woodsplitter. Watch that spelling as I did a typo and put an extra i in plumbstriaight.
This setup works well for that heavy wood as you can see and with having the T knife taking two pieces off the bottom of the block as you work through it makes it easy. I later put a better engine on it and there are no hesitations.
16001 (A55853)
16001 (A55853)
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2023 CATERPILLAR 120 MOTORGRADER (A60429)
2023 CATERPILLAR...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2023 SNORKEL A46JRT ROUGH TERRAIN BOOM LIFT (A59823)
2023 SNORKEL...
