Log Splitter Power
/ Log Splitter Power #1
RonL
Banned
Worcester, Massachusetts
Caterpillar 416C IT, Caterpillar D3G, previously owned a Ford 1910
Is anyone with a 4 inch piston on their log splitter not happy with the power it produces? Does anyone wish they had a more powerful (not faster ) splitter?
RonL
/ Log Splitter Power #2
Have you ever met a pants wearing man that didn't want more power???? /forums/images/graemlins/grin.gifBefore I put my 20 HP Kohler on my homemade tractor....it powered my 3 inch ram....putt..put..putt....SPLIT!!! /forums/images/graemlins/shocked.gif
/ Log Splitter Power #3
I plumbed in a 0-5000 psi pressure gauge when I set my splitter (4" x 24" three point) up a few weeks ago because I was curious about what kind of force the wood was requiring to split. I burn only hardwoods; red oak, white oak, beech, and a little bit of hard maple, splitting both green and seasoned.
In order to monitor the pressure you need to watch the needle as it's splitting for it to spike, normally it will read zero because of the open spool design ofthe splitter's valve. With everything I've split I've never seen it go above 1200 PSI. The hydraulic system goes to 2700 PSI so there's plenty of reserve for what I'm doing.
If you're planning on a 4-way splitter (splits log into 4 pieces at once) then a larger cylinder might be preferred. My present setup only splits into two pieces though I'll eventually rig something up to try 4 way splitting.
/ Log Splitter Power #4
I've been using a stand-alone log splitter with a 4" cylinder powered with a 10 HP briggs. Power is never a problem even when splitting gnarly maple. Hydraulic pressure probably does not reach 2000 psi at any time since there is *lots* of surface area with that large a cylinder.
I would rather have a bit faster ram speed. That 4 inch cylinder requires a high volume pump to make it move quickly.
Lou Braun
Looks like a 4" piston should be adequate for just about any splitting.
RonL
/ Log Splitter Power #6
When I built my logsplitter 5 years ago, I used a 5 inch cylinder,12hp Briggs I/C and a 16gpm 2 stage pump. A 5 inch cylinder has approx 19.62 square inches of surface area. Given this, at 2000psi you are making 19.62 tons of pressure per square inch. The formula for figuring square inches is Pi x radius squared so... 3.14x2x2=12.56 square inches for a 4"cylinder. Again at 2000psi you would make approx. 12.5 tons psi.
With my logsplitter I don't ever recall it going over about 1500psi to split anything, including wet elm, although it did kick down to the second stage. The way TSC and others get their 30+ ton rating is by using welded cylinders( non rebuildable) and boosting pressures up over 3000 psi. Most rebuildable cylinders have a working pressure in the 2500 psi range.
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
Skid steer Asphalt attachment (A61567)
Skid steer Asphalt...
Towable Generator (A60352)
Towable Generator...
2013 Caterpillar TL9430 (A64126)
2013 Caterpillar...
Adams 350T 10T Tender (A61307)
Adams 350T 10T...
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
