Log splitter hydraulics ?
/ Log splitter hydraulics ? #1
72Wagon
Central Virginia
john deere
Building a log splitter, the question I have is the pump outlet is 1/2 npt, the valve inlet is 3/4 npt, what size hose should I use to connect the two? I am guessing 3/4 would be best and reduce at the valve. It is a 13.6 gpm pump. Valve is rated up to 20 gpm.
Thanks
Kevin
/ Log splitter hydraulics ? #2
Yes, 3/4 hose is fine you should use a ''step fitting'' that is a 1/2 npt to 3/4 or #8 hose. Then standard 3/4 at valve end. This fitting is a crimp on fitting that anybody that makes hoses should have. It will also keep you from having to buy additional fittings keeping things neat.
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
2022 Case CX145D SR Hydraulic Excavator (A61572)
2022 Case CX145D...
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
12 in. WRXLS Excavator Bucket (A64194)
12 in. WRXLS...
John Deere 5045E for sale
John Deere 5045E...
