Log splitter hydraulics ?
   / Log splitter hydraulics ? #1
72Wagon
Central Virginia
john deere
Building a log splitter, the question I have is the pump outlet is 1/2 npt, the valve inlet is 3/4 npt, what size hose should I use to connect the two? I am guessing 3/4 would be best and reduce at the valve. It is a 13.6 gpm pump. Valve is rated up to 20 gpm.
Kevin
   / Log splitter hydraulics ? #2
Yes, 3/4 hose is fine you should use a ''step fitting'' that is a 1/2 npt to 3/4 or #8 hose. Then standard 3/4 at valve end. This fitting is a crimp on fitting that anybody that makes hoses should have. It will also keep you from having to buy additional fittings keeping things neat.
2018 MACK CHU613 DAYCAB WINCH TRUCK (A53843)
2018 MACK CHU613...
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
1999 KENWORTH T800 DAY CAB (A54607)
1999 KENWORTH T800...
90018 (A48082)
90018 (A48082)
Informational Lot - Financing (A53473)
Informational Lot...
