Log Splitter Functionality
/ Log Splitter Functionality #1
LouieJunior
Platinum Member
Moline, Illinois
JD4052R Open Station
I have Electrohydraulic Third SCV at the rear of my tractor. I control using my thumb on my joystick. It works fine with my grapple, hydraulic top link, and my stump grinder -- but could I hook-up and use a log splitter?
Seems like I would have to have my thumb on the switch and simultaneously be behind the tractor operating the Splitter. Am I correct?
Title should read: Log Splitter Functionallity
/ Log Splitter Functionality #2
Is the switch a momentary or a lock switch?
Do you have to hold the switch to use the stump grinder, and if not, then you can use the valve with a log splitter.
You need continuous flow.
I don't have continuous flow -- or a lock. When I take my thumb off the button, the flow stops.
Same thing with my loader functions -- lift & curl.
/ Log Splitter Functionality #4
Then you need a PB line to feed the log splitter.
Your loader valve probably has PB if it is feeding the scv valve, so you could run a hose to the back with a QD for the BH. BH return can go to a tank line or to the filler cap. If your BH valve has PB, then you can add it is series with the scv valve.
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
20' Reids Trailer (A62613)
20' Reids Trailer...
300 Gal Portable Fuel Tank (A64127)
300 Gal Portable...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A65054)
(INOP) 2013 MACK...
Bobcat Pallet Forks (A64127)
Bobcat Pallet...
2010 GMC 3500, Crew Cab, 2WD, Dually (A62679)
2010 GMC 3500...
