Log Splitter for Mahindra 3510
   / Log Splitter for Mahindra 3510 #1
terraformer
N.E. Mo
Mahindra 3510, Bolens G192/Iseki 1910
Does anyone else have a PTO log splitter on their Mahindra? As you know the Mahindra has a rear hydraulic port. I read about open and closed systems and that the device need be matched to the machine. I am unsure. I got my Mahindra from a used equipment dealer 150 miles away. Hauling the tractor to the dealer is not an option really for me.
TIA
   / Log Splitter for Mahindra 3510 #2
If you have a PTO log splitter, it would have its own oil reservoir, and pump, which would attach to your PTO on your tractor. If your splitter powers from your tractor hydraulics then I believe your tractor already has the hydraulic ports to operate it.
   / Log Splitter for Mahindra 3510 #3
Yep, if you use he rear remotes, they have one at tractor supply for under $1k. I would just use the remotes. Know its not much help if you wanted to use the pto though.
   / Log Splitter for Mahindra 3510 #4
I have been looking for a 3 point wood splitter also. In my research I would recommend a PTO driven one. They will provide a faster cycle time on the ram. Just my 2 cents.
   / Log Splitter for Mahindra 3510 #5
You have about 7.8 GPM from your implement pump.
Hydraulics:
Type: open center
Valves: 1
Gear Pump flow: 7.87 gpm [29.8 lpm]
Hydro Pump flow: 6.4 gpm [24.2 lpm]
Gear Steering flow: 3.57 gpm [13.5 lpm]
Hydro Steering flow: 4.60 gpm [17.4 lpm]
You have 28.7 PTO HP
You could run a PTO pump, Max. output: 17.1 GPM @ 2,000 PSI & 27.4 Hp input
7.8 CU IN PRINCE HC-PTO-9A PTO PUMP 540 RPM
2012 Buick Enclave Premium SUV (A50860)
2012 Buick Enclave...
2012 Ford F-350 Service Truck (A50860)
2012 Ford F-350...
Case 84in Hydraulic Hopper Sweeper/Broom Skid Steer Attachment (A49461)
Case 84in...
Toolbox (A50860)
Toolbox (A50860)
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A49461)
12-Wheel Pneumatic...
2000 PETERBILT 357 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
