Log Splitter for Mahindra 3510
/ Log Splitter for Mahindra 3510 #1
terraformer
N.E. Mo
Mahindra 3510, Bolens G192/Iseki 1910
Does anyone else have a PTO log splitter on their Mahindra? As you know the Mahindra has a rear hydraulic port. I read about open and closed systems and that the device need be matched to the machine. I am unsure. I got my Mahindra from a used equipment dealer 150 miles away. Hauling the tractor to the dealer is not an option really for me.
TIA
/ Log Splitter for Mahindra 3510 #2
If you have a PTO log splitter, it would have its own oil reservoir, and pump, which would attach to your PTO on your tractor. If your splitter powers from your tractor hydraulics then I believe your tractor already has the hydraulic ports to operate it.
/ Log Splitter for Mahindra 3510 #3
Yep, if you use he rear remotes, they have one at tractor supply for under $1k. I would just use the remotes. Know its not much help if you wanted to use the pto though.
/ Log Splitter for Mahindra 3510 #4
I have been looking for a 3 point wood splitter also. In my research I would recommend a PTO driven one. They will provide a faster cycle time on the ram. Just my 2 cents.
/ Log Splitter for Mahindra 3510 #5
You have about 7.8 GPM from your implement pump.
Hydraulics:
Type: open center
Valves: 1
Gear Pump flow: 7.87 gpm [29.8 lpm]
Hydro Pump flow: 6.4 gpm [24.2 lpm]
Gear Steering flow: 3.57 gpm [13.5 lpm]
Hydro Steering flow: 4.60 gpm [17.4 lpm]
You have 28.7 PTO HP
You could run a PTO pump, Max. output: 17.1 GPM @ 2,000 PSI & 27.4 Hp input
7.8 CU IN PRINCE HC-PTO-9A PTO PUMP 540 RPM
2019 K&K Equipment Trailer, VIN # 1K9PE2029KA175459 (A65563)
2019 K&K Equipment...
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
2022 EZ-GO ELITE...
2018 CHEVROLET SILVERADO 2500HD (A65643)
2018 CHEVROLET...
2021 PermaGreen Ride-On Speader-Sprayer (A64194)
2021 PermaGreen...
