Log Splitter for Mahindra 3510
   / Log Splitter for Mahindra 3510 #1
terraformer
N.E. Mo
Mahindra 3510, Bolens G192/Iseki 1910
Does anyone else have a PTO log splitter on their Mahindra? As you know the Mahindra has a rear hydraulic port. I read about open and closed systems and that the device need be matched to the machine. I am unsure. I got my Mahindra from a used equipment dealer 150 miles away. Hauling the tractor to the dealer is not an option really for me.
TIA
   / Log Splitter for Mahindra 3510 #2
If you have a PTO log splitter, it would have its own oil reservoir, and pump, which would attach to your PTO on your tractor. If your splitter powers from your tractor hydraulics then I believe your tractor already has the hydraulic ports to operate it.
   / Log Splitter for Mahindra 3510 #3
Yep, if you use he rear remotes, they have one at tractor supply for under $1k. I would just use the remotes. Know its not much help if you wanted to use the pto though.
   / Log Splitter for Mahindra 3510 #4
I have been looking for a 3 point wood splitter also. In my research I would recommend a PTO driven one. They will provide a faster cycle time on the ram. Just my 2 cents.
   / Log Splitter for Mahindra 3510 #5
You have about 7.8 GPM from your implement pump.
Hydraulics:
Type: open center
Valves: 1
Gear Pump flow: 7.87 gpm [29.8 lpm]
Hydro Pump flow: 6.4 gpm [24.2 lpm]
Gear Steering flow: 3.57 gpm [13.5 lpm]
Hydro Steering flow: 4.60 gpm [17.4 lpm]
You have 28.7 PTO HP
You could run a PTO pump, Max. output: 17.1 GPM @ 2,000 PSI & 27.4 Hp input
7.8 CU IN PRINCE HC-PTO-9A PTO PUMP 540 RPM
2022 Argo Xplorer XRT 570 LE 4x4 ATV (A48082)
2022 Argo Xplorer...
2016 Dodge Challenger SXT Coupe (A48082)
2016 Dodge...
1972 Ford F600 Grain Truck (A51039)
1972 Ford F600...
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A48082)
2005 Northwood...
2011 MACK GU713 (INOPERABLE) (A50854)
2011 MACK GU713...
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
