LOG SKIDDING/GRAPPLE
/ LOG SKIDDING/GRAPPLE #1
flINTLOCK
Platinum Member
PA
NH TC40DA 2002
I'm going to be clearing some trees for food plots. If I can get good purchase on a log end on centered in grapple and can lift it a foot or so, can I damage the loader by trying to skid it driving backward 20 or 30 feet to larger clearing to cut up for firewood. I have NH TC40DA with 17LA loader and ANBO 66" grapple.
/ LOG SKIDDING/GRAPPLE #2
I drag trees backwards with my loader all the time.
Are you using chains or grapple??
That's a good sized tree and stump to lift. What is the capacity of your loader? I haven't used my new tractor yet and am trying to get some idea of what to expect. Lift capacity on my rig is 1500#. 17LA loader on NH 40DA
/ LOG SKIDDING/GRAPPLE #6
I think the 17 la will do more than it should. I would grease it every day as the manual specs.I had a 16 la on my TC40d it was a strong loader for the size tractor.
/ LOG SKIDDING/GRAPPLE #7
16LA=1,800-2,000 lbs.
17LA =1,760-1,955 lbs.
7309 =1,350-2,450 lbs.
This is according to NH's specs. Mine's the 7309 and it depends on what tractor it's mounted on. I figure I'm around 2000lbs. I've been pretty rough on it. I've also got a set of stone forks and a homemade set of forks.
/ LOG SKIDDING/GRAPPLE #8
On the other end of the tractor, I once bent a lift arm on a B7100 while dragging a long log and turning hard. The log hung up and didn't turn while the tractor did.
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
Wacker PT3 Water Pump (A65640)
Wacker PT3 Water...
(16) Kinze 3000 Precision Plant Corn Meters (A65640)
(16) Kinze 3000...
2022 EZ-GO ELITE...
(16) Kinze 60 Cell Bean Plates (A65640)
(16) Kinze 60 Cell...
