locknlube cupler for a grease gun
   / locknlube cupler for a grease gun #291
Thanks for that info... never heard of a G.coupler. It is quite a bit cheaper than the LnL, plus I like how the pins "grab" the zerk and it doesn't wobble
I've just ordered an Alemlube coupler here in Australia, but no idea where they're from. They look much the same as the LNL.
   / locknlube cupler for a grease gun #292
EDIT - Just had a closer look at the photo. "Made in South Africa, patented in the US"
   / locknlube cupler for a grease gun #294
   / locknlube cupler for a grease gun #295
Yes, but a number of people don't know about the loosening tip idea. as evidenced by the old thread I posted. And that includes people who have been greasing machinery all of their lives.:)
Tightening and loosening doesn稚 to work on a few fittings I have.
   / locknlube cupler for a grease gun #296
I keep a well stocked assortment of zerks. I have no patience for one that leaks.
   / locknlube cupler for a grease gun #297
296 posts on this! :)
I always run into the same issue, some zerks are in a location that you can't reach it to loosen the original gun tip once you're done and if you left it loose enough before squirting in grease, it leaks back out around the zerk.
And usually it's not the zerks that won't take the grease, it's the grease space is so tight where the parts fit together that the grease has to be applied with a lot of pressure to actually space the parts. sometimes you can move or exercise them and get the space to open up for easier application. Hope that makes sense.
   / locknlube cupler for a grease gun #298
I think everyone that is thinking of a powered grease gun should start with a lock n lube and a lever style manual grease gun. I just got a lock n lube on my manual grease gun this spring but I have to say I am no longer thinking of getting a powered gun and so far it fits on everything I have tried it on.
   / locknlube cupler for a grease gun #299
I second that
Just finished tractor in record time. 3 fittings to go, I need to lift fel. Clean hands!
I’m sold
Anybody see my picture of the right angle adapter with wax in it? Hmmmmmm
   / locknlube cupler for a grease gun #300
Yep, could it be grease? Maybe they tested it before shipping it.
2013 Nissan Juke SUV (A50324)
2013 Nissan Juke...
CATERPILLAR 320FL EXCAVATOR (A51242)
CATERPILLAR 320FL...
John Deere Quick Attach Pallet Forks (A50514)
John Deere Quick...
2016 POLARIS RANGER ETX EFI 00HC RTV (A51243)
2016 POLARIS...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
