locking wedge - in 3pt Spring- remove/release?
/ locking wedge - in 3pt Spring- remove/release? #1
Dave5264
Near North Ontario Canada
08 Montana C5264, 2011 McCormick CX100 XS
Hi, have a montana, 5264. its the old technology, (60's) the 3pt assemply has a large flat spring, that can be locked via a hinged wedge. For running stuff like a grader blade the wedge is inserted, for running a plow using draft control, its removed.
Unfortunately, i cant remove it !, followed the instructions in the manual (lift the 3pt, and raise the float / position levers, remove wedge) but its stuck.
when i inserted it, it would flip in and out easily, now its seems there is spring pressure on it from the big flat spring, and I cannot figure out how to release it.
Please help !
THANKS
/ locking wedge - in 3pt Spring- remove/release? #2
You might be better of posting this in the Montana forum.
I can't even picture that assembly, but it might be worth a phone call to your dealer. This probably isn't the first time this problem has arisen.
This particular tractor isa UTB Romanian (not the typical Montana), the same tractor was made for Ford, Universal and many others over the years.
will try and get a picture. been the same since the 60's
2026 SDLANCH SDLC2020 High-End Carport (A64194)
2026 SDLANCH...
2014 CATERPILLAR 938K WHEEL LOADER (A65053)
2014 CATERPILLAR...
ELECTRIC POWER WASHER (A64278)
ELECTRIC POWER...
2005 CATERPILLAR 416D BACKHOE (A65053)
2005 CATERPILLAR...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
Carryall 1700 4x4 (A61574)
Carryall 1700 4x4...
