Mowing Locking mower deck on 2320
/ Locking mower deck on 2320 #1
swomack
Tennessee
John Deere 2320
Am I supposed to be able to lock the 62D mower deck and keep it from lowering by turning the height adjuster to the lock position and if I can should it lock at eh fully raised position or do you have to raise and lower it until you find where it will lock?
/ Locking mower deck on 2320 #2
Assuming you dont have the independent lift (runs off the FEL connection), you raise the 3 pt/mower up as far as it goes and then turn the height control knob clockwise as far as it will go. You will hear a clunk sound.. When you go to lower the 3pt the mmm will still drop an inch or so though..
Brian
I don't really hear a clunk it's more like two wrenches being tapped together. It will hold the deck up but you have to fiddle with it to get it to hold and even then it doesn't seem to be fully engaged.
/ Locking mower deck on 2320 #4
hello my jd2320 dose the same i raise the deck up with the loader joystick i guess that is called the fel? then i turn to lock it still drops about an inch ,i dont like this system thou i somtimes like to mow high in some spots but it drops .i thought the FEL system was the independent lift? is there another system for raising the mmm so it dosent drop .
/ Locking mower deck on 2320 #5
Sounds like the same problem described on another thread on the MMM on the 2305. I don't like this system the way it "works" on mine.
2014 PETERBILT 567 (A67714)
2014 PETERBILT 567...
2009 Ford Ranger Pickup Truck (A66736)
2009 Ford Ranger...
23.1-26 Tires - Set of 2 (A68134)
23.1-26 Tires -...
LAWN MOWERS/WEEDEATER/HEDGER (A67714)
LAWN...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
2010 ALLMAND MAXI-HEAT MH1000 HEATER (A68842)
2010 ALLMAND...
