Locations lost after software change?
/ Locations lost after software change? #1
FTG-05
Elite Member
TN
Kubota L4330 GST w/FEL, Kubota RTV-XG850, Kubota ZD326S
I no longer see members locations in their username area. I don't even see mine.
I PM'd one member and he says he can see locations.
What's up. ETA: I'm using Windows Professional 7 and Firefox 94.0.1.
Thanks,
/ Locations lost after software change? #4
No change on Chrome and W10:
Let's see if this works:
My post is just above Wagtail: No TN, no post number; just the Username and Status.
/ Locations lost after software change? #7
hmm
its not showing joined, messages, location, or tractor type.
hmm
/ Locations lost after software change? #8
OK I think I found it.
Go into your account
Under Settings
Go to Settings
Under STYLE, you probably have DEFAULT set.
Change DEFAULT to TBN2020
Scroll down to the bottom and SAVE,
Then see if that did it.
/ Locations lost after software change? #9
It'll change the total look of the site, but you'll get those items back.
I haven't played with it that much, so poke around and see what else is in there under settings.
Hope that helps.
/ Locations lost after software change? #10
I am using TBN2020.
And really like 50 "Threads (Posts) per page":
/ Locations lost after software change? #11
On my iPhone, if you reduce the font size to 50% (click on the AA at the top left in the location bar), then the font size is small enough to fit all of that info on the screen
/ Locations lost after software change? #12
Safari on iPad here. Not using the app. I never consciously switched to TBN2020 but I see that is my default setting.
Under Settings
Go to Settings
BINGO!!!
2001 Freightliner FL112 T/A Wet Kit Day Cab Truck Tractor (A64556)
2001 Freightliner...
30 Yard Roll Off Dumpster (A65579)
30 Yard Roll Off...
NEW Landhonor LHR-AIW1  1" Air Impact Wrench  (A62679)
NEW Landhonor...
HD Running Gear (A66408)
HD Running Gear...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
2018 FREIGHTLINER M2106 DUMP TRUCK (A63276)
2018 FREIGHTLINER...
