loading tires
/ loading tires
hey fireman thats what I used to do with the old mf135. But it was so old I wasnt worried about the rims rusting out.I even had a air hose chuck hooked to a garden hose and after filling and letting all the air out I would preasurize the tire with water. Just wnated to make sure I wouldnt have to buy rims in a few years for the kubota.
/ loading tires #12
OVRSZD, I have one of my famous dumb questions.I had my tires filled at the dealer,or at least they told me they did it before it was delivered.Never having had this done before how do I know they were filled and whether or not they were filled past the axle like you mentioned? Some way to check?.
Told ya it was dumb.
/ loading tires #13
You can let out air and the fluid should come out. Just be sure to check it with the valve stem in the 12:00 position first. Then move the tractor so the valve stem is at 1:00, 2:00 and finally to see if it's filled above the axle, check when the valve stem is rotated enough so it is level (near) with the top of the axle. Normally, a dealer will fill the tires with the valve stem at 12:00 to that level, above the top of the rim.
/ loading tires #14
Yep, that's how you do it. Easier if you have someone to watch or drive and loosen the core until air is hissing out at 12:00, then drive forward slowly until fluid spits out, that's your filled level!!! Retighten core and you are all set.
If you are working alone and have a jack, raise the tire off the ground and do the above by turning the tire by hand until it spits!!!
/ loading tires #16
I have asked at more than one dealer and researched online regarding filling of tires without tubes. The recommendation from dealers and from tire/manufactureres/dealers is to fill the tires to the point where the rim is completely submerged (about 75%). To develop rust, you need moisture and oxygen. Therefore, if the rim is constantly submerged, rust is apparently not a significant problem because the rim is not constantly exposed to oxygen and the available oxygen is limited to the 25% fill. On the other hand, filling to less than the 75% will cause the rim to constantly submerse and O2 exposure accelerating rust/corrossion.
/ loading tires #17
If you don't mind waiting, when it's cool nights and warm days and a bit humid you'll see the condensation line on the tires if parked in an open shed. Of course the dribble test is quicker;) .
Jim
/ loading tires #18
Jim
Yep, that is why as mentioned somewhere above in this thread, they suggest you fill to cover the rim inside. So when it does that night sweat, it doesn't condense on the steel wheel and cause rust. I don't run mine that full so it's important to have anticorrosive additive.
Used Landpride GR1525 Stump Grinder
Used Landpride...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A61166)
IMPORTANT PLEASE...
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
2014 JLG 6036 6,000lb 4x4 Rough Terrain Telehandler (A59228)
2014 JLG 6036...
