Loading Tires???????????
/ Loading Tires??????????? #1
JimR
Elite Member
Central Ma.
Kioti NX4510HST
Has anyone ever loaded their own tires? What did you put in them Calcium, antifreeze, etc?????. Where did you get a pump to fill them or did you make one?
/ Loading Tires??????????? #2
Low temp WW fluid. The item to use comes from NAPA and screws on the valve stem. It let's you burp the air. About 7 bucks. There was a great thread on this a while back.
Thanks for the info. I'll be heading there today. I guess it will take many many gallons to fill the tires up.
/ Loading Tires??????????? #4
well, lets see if I can figure out how to give you this link I got from someone else here.
tires
Yeah, I think that worked
Mike
/ Loading Tires??????????? #7
I have a real problem with using windshield washer fluid. That stuff costs nearly a buck a gallon!
Why not fill with plain water and add a gallon of alcohol per tire?
/ Loading Tires??????????? #8
Hi
I am thinking about using used hydraulic and used motor oil to load my tires, what do you folks think? wont have to worry about rust
Charlie
/ Loading Tires??????????? #9
I don't know that I would do that. Some oils have additives that destroys certain rubbers.
/ Loading Tires??????????? #10
</font><font color="blue" class="small">( Hi
)</font>
Oil is lighter than water.
Mike
/ Loading Tires??????????? #11
Not to mention the environmental issue if there's a leak. Yeah, the ww fluid is a buck a G., but the difference is cost isn't that way off. I had an incident with a chloride tire once. Don't want to go through that again. Anti-freeze is not very environmental either. Including the low-tox stuff. I preferred something that would give a fair amount of weight and be as 'friendly' as possible should a leak occur. I've heard a lot about the foam filled tires. I was thinking of doing an experiment with the low expanding canned foam on a junk tier to see how that works. I'm stressin' already from the frequent flats. Always finding the hidden barbed wire in the 'lawn'......
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
2006 Kawasaki Bayou 250 (A64127)
2006 Kawasaki...
159115 (A60430)
159115 (A60430)
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
2005 JLG BOOM LIFT (A59228)
2005 JLG BOOM LIFT...
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
